Amin
Rep Power: 14 ![]() |
Hi friends!
I'm trying to analyse a centrifugal compressor in ANSYS Fluent 14.5 so I'm using "match control" in ANSYS meshing for generating periodicity mesh! but when I'm updating generated meshing ANSYS says this error: "The mesher cannot find matching topology for following topology.please verify that the topology is the same shape and size. also verify the position and orientation of any associated coordinate systems." I checked the geometry and the faces are same for both sides and the edges and surfaces area are equal! Can anyone help me? |
Amin
any solution for this problem?
any help? any one? ...? |
Amir mohammad farhoudi
Rep Power: 0 ![]() |
I got this error too, please help if anyone know how to get through this error.
thanks |
Amin
it means the face you've selected it's not completely equal,
also sometimes ansys makes this error because the reference frame you've chosen for the matching control isn't valid |
Shubham Deshmukh
Rep Power: 10 ![]() |
I too had a similar problem. Finally, I got the solution to this.
Actually, I had to import a turbine blade (iges) and subtract it from a domain created in Ansys DM. When I first imported the geometry and then made the domain in DM, the Mesh module showed the same error. I think importing the geometry into DM may change the coordinate system at times creating slight error, which I confirmed by creating a new coordinate system (using Type:From Coordinates and selecting a vertex which had to be on axis - but this was off-center which created the problem). Solution: First Creating the domain/ dummy sketch in DM and then importing external geometry resolves the problem. Shubham |
Mohammed Ahmes
Shubham_SD... Thank you for your help
ansys meshing, compressor, match control, periodic bc |
Problems of running Oscillating plate tutorial | vovogoal | CFX | 20 | February 4, 2016 07:03 |
Ansys CFX exited with return code 1. | dheelibun | CFX | 8 | May 7, 2014 07:21 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 15:34 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation | peterputer | ANSYS Meshing & Geometry | 0 | May 15, 2012 08:53 |
