ICEM Surface problem
Like Tree1Likes
  • 1 Post By kad
Old   May 6, 2014, 05:26
Default ICEM Surface problem
Simon
error404 is on a distinguished road
Hey,
I´ve got a problem with generate a surface in ICEM. I want to create a surface including 4 curves (pic.1). The surface is "ok" (pic.2). But when i´m looking closely (pic.3), you can see that there is an additional curve and the surface isn´t referenced on the curve, which was choosen.
Can anybody explaine whta was happend?
thx Simon
error404 is offline   Reply With Quote
Old   May 7, 2014, 07:27
Javi
FJSJ is on a distinguished road
Hi Simon,
You can try to set up a better tolerance number for you curve. Have you tried to see the curve with "show full" option?
FJSJ is offline   Reply With Quote
Old   May 7, 2014, 07:48
Simon
Thanks,
but I think "show full" is only a viewing option and no tolerance option?
Old   May 7, 2014, 08:15
Javi
Do you have geometry file? Can you share it?
Old   May 7, 2014, 09:34
kad
kad will become famous soon enoughkad will become famous soon enough
Originally Posted by FJSJ View Post
Hi Simon,
Try this by reducing model tolerances under general -> model.
Originally Posted by error404 View Post
Thanks,
You are right, but the option "show full" displays the surface triangulation as it actually is. The other options show simplifications of your model.
error404 likes this.
kad is offline   Reply With Quote
Old   May 7, 2014, 09:40
Simon
Thank you,
now it works.
Old   June 6, 2014, 05:33
Simon
i´ve got a problem with the geometry tool in ICEM. I want to close a gap between surfaces on an edge. I ´ve got a very thin first layer and when there is a gap, there will be a wrong mesh. I tried the tool to close the gaps, but I think the tolerance is to high.
How can I adjust the merge tolerance?
Thx
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[ICEM] Simple meshing problem in ICEM fkh ANSYS Meshing & Geometry 6 February 14, 2012 14:01
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
ICEM meshing problem Forrest CFX 4 May 25, 2005 19:37
