[ICEM] ADINA interface problem
Like Tree2Likes
  • 1 Post By pici
  • 1 Post By pici
Old   April 5, 2014, 12:18
Default ADINA interface problem
Daniel
Daniel_Khazaei will become famous soon enough
Hello to all...
I have a question about ADINA interface in ICEM CFD.
I am trying to output the generated mesh into ADINA simulation software, however ADINA is unable to read the input file. (ADINA 8.9)
Reading through the input file, I can see that ADINA interface in ICEM CFD 15.0 is outdated and I think that is the problem:
"A D I N A - I N V E R S I O N 7 . 3 I N P U T F I L E"
Is there any work around for this problem?
Best wishes
Daniel_Khazaei is offline   Reply With Quote
Old   May 3, 2014, 14:33
pici's Avatar
Pierluigi Cirrottola
pici is on a distinguished road
Originally Posted by Daniel_Khazaei View Post
Hello to all...
Best wishes
Hi Daniel,
I concord with you that ADINA 7.3 is very old.
If you can, you should try to export your problem using Nastran format (.op2 or .dat) .
In particular .op2 is very well accepted by ADINA 8.9
I hope to be helpful.
Bye
Piero
Daniel_Khazaei likes this.
pici is offline   Reply With Quote
Old   May 3, 2014, 15:00
Daniel
Originally Posted by pici View Post
Hi Daniel,
Bye
Piero
Thank you very much for the answer.
I am currently using Nastran format to export my model.
However, I am facing another issue using imported Nastran model.
ADINA wont allow me to use spatial function in this situation (for example applying parabolic velocity profile).
Best wishes,
Danial Khazaei
Old   May 5, 2014, 07:58
Exclamation nastran to Adina
pici's Avatar
Best wishes,
Danial Khazaei
Yes, it is right. It happens because you don't have any kind of geometry (with associated mesh data) to use to define spatial functions.
Only possibility it to try to define an Element-face set where assign loads; but I'm not sure that is possible to apply Spatial Functions: Handbook says yes, but load widget doesn't show the 'Spatial Function' tab.
Bye
Piero
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
a problem about the interface in CFX 309558927 CFX 2 March 14, 2014 20:37
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
interface boundary problem Rashad FLUENT 0 April 23, 2007 06:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
