[Workbench] SCRIPT for geometry / meshing
Like Tree1Likes
  • 1 Post By Nigirim
Old   April 1, 2014, 22:49
Thumbs up SCRIPT for geometry / meshing
Kapi is on a distinguished road
Hi guys,
I am starting this new thread to talk to people who are doing scripting for geometry and meshing like me.
Query:
When we run .wbjn file thru batch file and call .js files to do geomtry and mesh. After it finishes meshing we use...
mesh1.Exit()
and mesh closes.
Now my problem is when I run multiple .wbjn files one after the other from the same batch file. The second .wbjn file dosent execute unless I close the first WB.
Do you guys have any idea how to automatically close WB after meshing is done?
I think it cant be done from .wbjn file, there shud be some function to run in batch file itself to close first WB and start next .wbjn file.
Any help will be highly regarded
Thanks in advance
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   April 2, 2014, 09:46
Nigirim is on a distinguished road
Hi Kapi,
you can close WB by simply adding -X to the command you start ANSYS with.
-X closes WB as soon as the script is completely executed.
Then you can open WB again for your other journal files.
Greets
Nigirim
Kapi likes this.
Nigirim is offline   Reply With Quote
Old   April 2, 2014, 18:56
Thanks for reply Nigirim,
so basically as we run the below command to open the WB and execute our code
"C:\Program Files\ANSYS Inc\v145\Framework\bin\Win64\RunWB2.exe" -I -R File_name.wbjn
what you are suggesting is to add -X in the above code and run?
like this?
"C:\Program Files\ANSYS Inc\v145\Framework\bin\Win64\RunWB2.exe" -I -R -X File_name.wbjn
Edit:
I just ran the above code using -X, what it is doing is opening the WB and closing straight after.
so basically it dosent run the .js code I have provided to make geometry and mesh and closes.
Could you provide the code which uses -X , I will try few things as well to get it working.
Cheers
Kapi
Old   April 2, 2014, 19:38
Got it working!!
Just add some code in Fil_name.wbjn and saved the WB as "check.wbpj"
then ran the below code
"C:\Program Files\ANSYS Inc\v145\Framework\bin\Win64\RunWB2.exe" -I -R File_name.wbjn -X check.wbpj
Thanks heaps for your suggestion Nigirim
Cheers
KAPI
Old   April 2, 2014, 20:33
Default Script Selective Meshing
New Query:
There are code available to run mesh thru java script, the problem is it meshes the whole thing in 1 go.
We can pick bodies manually one by one and mesh them or we can create worksheet inside for selective meshing.
I want my java script to pick bodies one by one from the tree(Model>Geomtry>Part>Body1) and mesh it, this way meshing is lot quicker when it comes to large model with lot of bodies and a coarse mesh.
The code I am using to mesh is below, it meshes everything in 1 go
ds.Script.doModelPreviewMesh();
I checked help and all in my model is having "Part" because if we go in Mesh help it says:
In a multibody part, if any child bodies have been meshed and refined, another child body is unmeshed, and you subsequently mesh the unmeshed body, the mesh state of all refined bodies in the part will be invalidated and re-meshed during mesh generation. Similarly, if one body is unmeshed and refinement is needed on another, generating the mesh will result in meshing and refinement of the entire part
Does that mean I cant do selective meshing in a part?
I tried doing this manually and it works without any problem.
So now I need code which can go into "Part" and select bodies one by one and mesh it.
Anyone with ideas?
Thanks in advance
Cheers
Kapi
Old   April 3, 2014, 08:44
Hi Kapi,
how does your script work in general?
Are you creating a new Workbenchprojekt every time you start the script or are you loading and modifying a existing project?
In general I would say it is possible, everything you can do in the GUI is handeld by XML and JScript.
But I am not 100% certain it works this way.
There are JScript commands that select the bodies in the Tree, I have never tried to select and then mesh the bodies one by one.
I have loaded a existing Workbenchproject and modified it. To mesh I just used the Worksheet I once created for every single body.
Greets
Nigirim
Old   April 3, 2014, 19:26
Hi Nigirim,
Thanks for replying back.
Yes I am creating a new project everytime because I have different geometry everytime.
It does work manually so I think it should work with codes as well.
I have tried few commands to work it out but was not successful and the reason I cant use worksheet is because I dont have similar name, size or pattern of bodies in the tree. Thats why I have to select bodies from tree at that instance and mesh it.
Could you please share your JS command to select bodies in tree, may b that can help in my case.
Is it possible to create worksheet thru JS commands and make that worksheet select the bodies from geomtery 'part'?
I see a problem in selecting bodies from tree when there is Part with multiple bodies because what we actually need the code should go in the tree, select part, go inside part and select bodies from top to bottom and mesh them.
I hope I am able to explain my problem.
Thanks
Kapi
Old   April 4, 2014, 08:33
Originally Posted by Kapi View Post
Hi Nigirim,
Hi Kapi,
its been a while since i last used the command for the Meshing tool, so I am not 100% certain that it is the same as for DesignModeler (This one i used way too much)
ag.guiScript.SelectFeatureNodeByID(BODY_ID)
I can't have a look at my old scripts, because I changed my workplace so I can't tell you the exact commands.
I used this command in a loop to select threw the bodies to give them Bodythickness.
I never made a Worksheet by Script and never took a look if it is possible, so I can't tell you if it works or not.
Hope this helps
Greets
Nigirim
Old   April 6, 2014, 19:40
Thanks Nigirim
the below code is for geometry not mesh sadly.
"ag" is used in geometry and "ds" is used in meshing to prefix the function
I have tried to do loop the body and mesh it but the problem I am facing is, unless I select a part or a body manually that code dosent execute.
so basically if I manually select a "body" in the tree and run my JS file it work smoothly but it dosent do anything if I select "geometry" or "Model" in the tree.
Making worksheet is outta question cuz I will not be able to give any specifics of bodies to work on it. the only thing left is to force my JS script to select a body and then run the script.
Lets c if I am able to do that.
If anyone else has any input here then it wil be really helpful
Cheers
KAPI
Old   April 16, 2015, 02:32
Smile
kar.coep is on a distinguished road
Hello Kapi,I am trying to achieve the same process as you are saying in this post. I have searched a lot, contacted Ansys guys but doesn't seem to get any documentation on DM and meshing programming as such. Can you give a intro on how to start with this programming or provide relative Jscript coding if it is easy? It would be really helpful.In DM what I am trying to achieve is:1. import external geometry from Creo2. Create inlet and outlet surfaces and have Fill3. Create named selections for inlet and outlet4. suppressing the body5. forming new part with new generated domainsAlso, is there a way to record Jscript coding in DM and Meshing?Thanks.
kar.coep is offline   Reply With Quote
Old   April 16, 2015, 03:11
Hi Kar,
Good Day!
There is no way to actually record the script but to hard code it.
Are you using Ansys 15 or 16?
I was told recently that in 16 there has been lot of documentation on scripting
To start with you need to go "Help" section and read about scripting("Ansys Customization"), its quiet useful and then Ansys Customer portal for examples which are very useful to understand the process!
Ansys Customization Toolkit (ACT) is the fully documented in Ansys 16
This way you will not only be able to script but will understand how to decode/ debug Ansys functions.
If you are stuck at some point then let me know, I can help you get functions for your JS.
Cheers
KAPI
Old   April 16, 2015, 04:58
Post
  #12
Thanks for the quick reply!!!
I am using Ansys 15
What I want to do in DM is
1. Import external geometry
2. Create Fill with 2 surface
4. Suppress geometry and form new part of domains
Old   April 16, 2015, 19:48
Hi Kar,
In Ansys 15: Help> Workbench>Scripting Guide, you should be able to find answers to your questions.
They have Usage Examples in that scripting guide as well. Have a go at it and check Customer Portal for Examples.
Hope it helps
Cheers
KAPI
[ICEM] Problem with ICEM Script Meshing asal ANSYS Meshing & Geometry 2 March 23, 2013 20:11
[ICEM] script for cylinder hexa meshing in ICEM Far ANSYS Meshing & Geometry 0 May 25, 2012 08:55
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
