[ICEM] hybrid mesh around airfoil - ICEM
Like Tree1Likes
  • 1 Post By shereez234
Old   February 13, 2014, 10:30
Default hybrid mesh around airfoil - ICEM
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hi every one;
I am trying to make a hybrid mesh in 2d for an airfoil. I have a structured mesh around airfoil to capture the boundary ( 2 times the chord length of airfoil, i.e. 1m).
I am able to get the tetras respect and project to the line elements when i keep edge spacing 2 to 0.0003. but when i change the spacing to 3e-05 or 3e-06 to make the y+ = 1 or less then the surface tetra elements (outer fluid region) does not respect the line elements and they are too big.
I used a build topology tolerance of 0.01 after which i segmented the surface and deleted the surface inside the airfoil.
any one could help me out? I need to make edge spacing small around the airfoil.
shereez234 is offline   Reply With Quote
Old   February 13, 2014, 12:46
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.cfd-online.com/Forums/ans...ary-layer.html
Far is offline   Reply With Quote
Old   February 14, 2014, 06:19
shereez234's Avatar
M Sereez
Thanks far. but I have obviously read all information before i posted that. in your tutorial on hybrid meshing you used a large first layer height. But when I did it with smaller first layer height , as i said before to around 4e-06, i found that the tetras dont respect the line elements. Have you tried and succeeded with smaller edge spacing?
Well, I found a way to solve the problem on my own. What I did is I split the collapsed edge come from trailing edge once more vertically and changed the edge spacing from there to the end of the edge. This does not affect the solution accuracy as well I guess
aero_head likes this.
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) Joachim ANSYS 3 April 24, 2016 17:52
ICEM 2D tetra mesh question kawamatt2 ANSYS Meshing & Geometry 18 March 3, 2014 11:56
about hybrid mesh in ICEM lian Main CFD Forum 1 February 27, 2008 12:01
