[GAMBIT] import to gambit
Like Tree1Likes
  • 1 Post By -mAx-
Old   February 10, 2014, 09:23
Question import to gambit
SJD
Sajjad
SJD is on a distinguished road
Hi ,
I am a beginner GAMBIT user,
I want to model (& make mesh files) various surfaces (in 2D) with various line equations and gambit can not make it because of limited geometry tools,
so I want to import lines(with math functions), I imported vertex & edges which I made in an excel file(with dat format), by means of "ICEM Input" with no problem,
Now I want to find a new way to import various geometry with out using vertex data! because it is not very accurate to draw functions using that way (using 1000 vertex data for example) as my teacher said.
Is there any math software can draw various math functions and create a valid file for GAMBIT???
Or which way should I use to import?
SJD is offline   Reply With Quote
Old   February 11, 2014, 01:47
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can do something with parameter:
http://www.google.fr/url?sa=t&rct=j&...rszbBlYKKuaGGg
SJD likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 11, 2014, 07:37
SJD
Sajjad
Thank you very much!!!
for your answer
I think this is useful for me!
Gambit Import error GUEST FLUENT 7 May 30, 2019 12:46
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 15:21
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Autocad import into Gambit Paul Main CFD Forum 5 July 12, 1999 05:19
