[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh |
January 13, 2014, 09:35 |
Yonatan Afework Tesfahunegn
Rep Power: 13 |
I have imported a Plot3D mesh file into ICEM, that contains WING and Farfield. However the wing tip is not covered by a surface. My interest is to create a surface at the tip and generate mesh. After that I want to extrude all the quad elements from the wing tip plane. I have followed the the steps as in this thread Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM. I managed to generate the mesh that I want as it is shown in the attached figures. Before I do the extrusion I wanted to check whether the wing tip surface is recognized by ICEM during writing output to fluent. Unfortunately,ICEM just skipping the wing tip elements, i.e the newly created quad elements at the wing tip. It says, Skipping part WINGTIP (not referenced by grid). How can I resolve this problem? Thanks for your help. Yona |
January 13, 2014, 10:33 |
Rep Power: 13 |
January 13, 2014, 13:43 |
Rep Power: 13 |
Hi Far,
I did not use blocking. After I import the plot3d mesh, I created curves and surface at the tip of using the Edit/Mesh->Facets tool. After that I generate the mesh using the surface mesh tools by respecting the line elements at the tip of the wing. |
January 21, 2014, 09:05 |
Solution
Rep Power: 13 |
Finally I am able to resolve my problem.
Rather than simply writing the wing tip surface elements to output, what I did was extruding this part together with other elements that are on the wing tip plane. This time ICEM did not skip any of the elements in the mesh. I want to thank you those of you who tried to help. Yona |
January 21, 2014, 10:06 |
#9 |
Rep Power: 13 |
Here are some snap shots: In the attachment you can ind the initial mesh before extrusion and final mesh after extrusion (Note that some elements are deleted for the purpose of illustration)
Structured or unstructured meshing of a STL file (surface) | Milad06 | Pointwise & Gridgen | 4 | April 25, 2013 11:55 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
3D wing + wind tunnel hexa structured meshing | icemaniac178 | ANSYS Meshing & Geometry | 9 | October 28, 2010 09:37 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
