[ICEM] Meshing of pipes with a nozzle
Like Tree4Likes
  • 1 Post By Far
  • 1 Post By diamondx
  • 1 Post By raghav
  • 1 Post By raghav
Old   December 19, 2013, 11:38
Default Meshing of pipes with a nozzle
nethmech's Avatar
nethmech
nethmech is on a distinguished road
Send a message via AIM to nethmech
Hello
I need help to mesh this geometry. I have tried to make Hexamesh using ICEM CFD but I haven't been able to maintain the quality.
https://www.dropbox.com/sh/18thrf5u3tp9slx/rWf-SA-cFD
Please let me know how to mesh it.
Thanks
nethmech is offline   Reply With Quote
Old   December 20, 2013, 15:26
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Somthing I tried before going back home. Not sure if it's correct, but you can get inspiration. I will get back on it if you need my help !!!
https://dl.dropboxusercontent.com/u/...86/Desktop.zip
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 21, 2013, 04:13
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.cfd-online.com/Forums/poi...tion-pipe.html
http://cfd-consultancy.webs.com/tutorials
http://www.cfd-online.com/Forums/ans...-icem-cfd.html
http://www.cfd-online.com/Forums/ans...-junction.html
Far is offline   Reply With Quote
Old   December 21, 2013, 10:23
nethmech's Avatar
nethmech
Thanks guys for the help.
I looked at the various files and tried to improve the mesh in my geometry. However I couldn't succeed entirely. The mesh now covers the profile/geometry however the nodes are not connected at several places.
Kindly give me feedback/advice on how to rectify the connectivity issues.
Old   December 21, 2013, 10:41
Far
Sijal
things is that , you have to add more ogrids and splits as compared to previous threads
nethmech likes this.
Old   December 21, 2013, 11:17
diamondx's Avatar
Ghazlani M. Ali
inside is complicated ,yeah not that easy !!!
Regards,
Ali
Old   December 21, 2013, 17:07
nethmech's Avatar
nethmech
Problem solved ..
Thanks everyone.
Old   December 23, 2013, 08:08
Thumbs up T-Pipe
Raghav
raghav is on a distinguished road
with some time spent, attained .4 quality
Far likes this.
raghav is offline   Reply With Quote
Old   December 23, 2013, 09:13
Far
Sijal
Originally Posted by nethmech View Post
Problem solved ..
Thanks everyone.
Excellent work
Old   December 23, 2013, 10:05
Raghav
thanks
Old   December 23, 2013, 16:15
nethmech's Avatar
nethmech
Raghav can you please send me your files.
Old   December 24, 2013, 00:27
Smile ICEM - TPipe - Files
  #12
Raghav
I have attached .tin file and .blk separately because of size constraints.
Have split the blocks into fluid and solid.
I have created some surfces to make the geometry closed. It will not harm the physics. U can define them as internal or interface in fluent.
Have put all the Surfaces in 1 part and Curves in another separate part.
you can redefine them as u want it to be.
Hope this helps you.
Regards,
Raghav
Old   December 24, 2013, 08:36
Thumbs up
  #13
nethmech's Avatar
nethmech
Thanks Raghav.
Old   December 24, 2013, 08:43
Raghav
Anytime. :-)
Was it the way u expected? ? I mean the way I split the blocks for fliud and solid?
Old   December 24, 2013, 09:01
nethmech's Avatar
nethmech
It was almost the way I expected. You have made concentric rings at the joint of the thin pipe and the cylindrical chamber.That's not required. Everything else in fine.
Check the files that I have attached.
I had problems in improving the mesh in ICEM CFD. However, from your files, I can see the way to improve the mesh in my files.
Thanks
Old   December 24, 2013, 13:58
Smile Reg. Concentric Rings & cylindrical chamber
  #16
Raghav
Hi Prabodh,
I appreciate your feedback.
Please go through the following points.
1. Reg. Concentric Rings(curves): I know they have trivial importance. But i created them to have associativity with edges and curves. I know surface association holds good but for safer side i consider curve association for the edges. And u can see that i have not divided those surfaces with these curves. Surface is single only. And i have used those rings or curves for association only
2. Reg. Cylindrical Chamber: I created the surface because i felt only that portion did not have a solid thick wall. so created that surface to include solid thick wall.
No problem. If u want fluid portion for this region, add those blocks in solid part to fluid part. And define that thin surface as Wall in fluent or in ICEM Boundary Conditions. you will get what u wanted.
3. And regarding the file you shared: Yes i can see where the problem was in your blocking strategy. Anyways, I hope this will improve your skills and strategies
Regards,
Raghav
Meshing a nozzle parvaz747 Mesh Generation & Pre-Processing 3 June 17, 2013 12:40
[ICEM] Help in meshing a 2D Nozzle????? harman79 ANSYS Meshing & Geometry 4 November 22, 2009 23:45
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
a hole in my structure after meshing a nozzle Ho CFX 7 October 3, 2005 09:33
UDF for dynamic meshing of 2D nozzle Anant FLUENT 0 July 29, 2004 10:18
