[ANSYS Meshing] unstructured mesh on 3D airfoil |
September 23, 2013, 06:13 |
WALI HASAN
Rep Power: 13 |
hello sir/mam
i am now currently generate an unstructured mesh on 3D airfoil with the following procedures max size of mesh .005 min size of mesh .002 mesh type " all tri" mesh method " patch independent" but when i compute the mesh with this specification,mesh near the edges generate inside the surface but in middle region of airfoil there is no defect in mesh So, please tell me what can i do so that near the edges mesh will generate smoothly on the surface not inside. I am enclose image image of mesh please inform me as soon as possible Last edited by wali; September 23, 2013 at 07:15. Reason: for enclosing image of mesh |
September 23, 2013, 10:00 |
vidyanand
Rep Power: 18 |
try with proximity and curvature with smooth transition-high
September 23, 2013, 15:01 |
WALI HASAN
Rep Power: 13 |
WILL U PLEASE ELABORATE IT because i am beginner and i dont much aware about this.
actually i want to generate surface mesh on airfoil.. thanks |
September 23, 2013, 21:04 |
Stuart Buckingham
Rep Power: 26 |
Hi Wali,
The function you will need to use is "Define Thin Cuts". Have a look in the help guide for details on how to use it. Alternatively, you could use the bottom up meshing approach (Patch Dependent Surface Mesh > Delauny/TG/AF). This method will not produce penetrating elements, but it requires your geometry to be perfectly connected. Good Luck Stu |
September 24, 2013, 12:29 |
Simon Pereira
Rep Power: 47 |
Yup, a combination of thin cuts, edge criterion, mesh refinement and other strategies will work. There are lots of detailed posts about these already on CFD online... They should be easy to find with those search terms.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
September 26, 2013, 07:52 |
response to stuart23
WALI HASAN
Rep Power: 13 |
sir the" thin cut "option is visible in volume mesh but i want to generate surface mesh on airfoil so how can i use this option and the guide which u send me is not working please send me again
thanks in advance |
September 26, 2013, 09:10 |
Simon Pereira
Rep Power: 47 |
Once you know the name of the option, you can search CFD-Online or the ICEM CFD doc for all the info you need...
September 27, 2013, 13:57 |
help
WALI HASAN
Rep Power: 13 |
hello dear
as i send the problems earlier regarding the mesh problem is like that when i draw the patch independent surface mesh on the delta shape surface mesh penetrates the surface and it creates the problem when i draw the volume mesh can anyone help me this is my post graduation project as i earlier attach the images of mesh but still again enclose the snaoshot of mesh please help me help me |
September 27, 2013, 14:32 |
#9 |
Simon Pereira
Rep Power: 47 |
Yes, we understand the problem...
We are telling you that there are several ways to fix it. 1) Setup "Thin Cuts" 2) Refine your mesh 3) Adjust "Edge Criterion" There are probably a few more, but these are the main ones. We have already posted lots of details on all of these. There is also much coverage in the help doc. Now you know the names of the solutions, a simple search (the help or CFD Online) will get you what you need to know.
September 27, 2013, 15:09 |
response
#10 |
WALI HASAN
Rep Power: 13 |
hello PSYMN sir
if u dont mind can u give me ur mail id so that i can send my geometry file please |
[ICEM] unstructured 2d airfoil mesh | Mazur | ANSYS Meshing & Geometry | 21 | June 7, 2023 04:48 |
[ICEM] Why do I have to convert my mesh to an unstructured mesh? | iznish | ANSYS Meshing & Geometry | 1 | November 2, 2012 09:29 |
[ICEM] Just started unstructured mesh ! | diamondx | ANSYS Meshing & Geometry | 6 | September 5, 2012 08:15 |
[ICEM] Extruded unstructured mesh association with boundaries, volumes, etc. | macfly | ANSYS Meshing & Geometry | 6 | August 7, 2012 17:13 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
