September 19, 2013, 05:10 |
boundary layer development in gambit
maaz ahmad
Rep Power: 15 |
i am working on wind effects on high rise building..i have to develop boundary layer along the wall on computational domain and building as well...gambit is showing message..initialization failed...with error code 1...i am unable to resolve this..kindly help me...
September 19, 2013, 06:16 |
Maxime Perelli
Rep Power: 41 |
more info please, with pictures
In memory of my friend Hervé: CFD engineer & freerider |
September 20, 2013, 02:25 |
kindly help me out...
maaz ahmad
Rep Power: 15 |
hi max..
i have to develop boundary layer on the ground and building surface..i am attaching pics here,, kindly look into it.. and help me ..out..thanx whole computational domain.jpg computational domain from different angles.jpg high rise building.jpg |
September 20, 2013, 02:33 |
Maxime Perelli
Rep Power: 41 |
then pick surfaces of ground and building...
take care of first cell's height. If you give an exotic value, then the BL propagation may fail http://aerojet.engr.ucdavis.edu/gamb..._blayer_create
September 21, 2013, 04:19 |
maaz ahmad
Rep Power: 15 |
max thanx for your response...i have changed the geometry of computational domain to resolve the error..
September 23, 2013, 04:33 |
maaz ahmad
Rep Power: 15 |
max.. can you tell me about the aspect ratio for boundary layer ....
September 23, 2013, 04:49 |
Maxime Perelli
Rep Power: 41 |
http://aerojet.engr.ucdavis.edu/gamb...spec_algorithm
with aspect ratio algorithm, you don't have fixed first cell' s height.
September 24, 2013, 00:32 |
maaz ahmad
Rep Power: 15 |
no dear the thing i wanna ask is that when we examine the mesh and in the option of quality type we click aspect ratio , then what is the range of this value that is best suited for a mesh.
September 24, 2013, 02:34 |
#9 |
Maxime Perelli
Rep Power: 41 |
from Help: "However, a general rule of thumb is to avoid aspect ratios in excess of 5:1. " --> http://aerojet.engr.ucdavis.edu/flue...ug/node155.htm
I would simply load the mesh in the solver and run a check mesh
September 27, 2013, 03:51 |
problem in udf for velocity proflie
#10 |
maaz ahmad
Rep Power: 15 |
vprofile.c UDF for specifying steady-state velocity profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; ( F_PROFILE(f, thread, position) = (10 + y/12.5)*cos(5.0/180.*3.1415927); } end_f_loop(f, thread) } DEFINE_PROFILE(inlet_y_velocity, thread, position) { /* insert your own code here*/ } max....in this udf while defining F_PROFILE(f, thread, position) = (10 + y/12.5)*cos(5.0/180.*3.1415927); can we use log formula also, if yes then please explain it for me..... |
September 27, 2013, 05:05 |
#11 | |
Rick
Rep Power: 27 |
see attached picture from udf manual. Daniele |
Questions about Boundary Layer Thickness and Turbulence Models | famerfamer | STAR-CCM+ | 3 | July 12, 2012 10:47 |
Boundary Layer roughness/ low reynolds wall treatment | Luigi_ | STAR-CCM+ | 1 | March 14, 2012 09:40 |
Boundary layer meshing problem in Gambit | Crystal | FLUENT | 0 | June 12, 2009 21:58 |
Gambit Boundary Layer | Anand | FLUENT | 0 | January 29, 2009 16:13 |
help for Gambit: 2 edges + 1 boundary layer | Peter | FLUENT | 0 | August 9, 2002 20:41 |
