[ICEM] 2D mesh extrusion and periodicity
Like Tree1Likes
  • 1 Post By cesarcg
Old   August 29, 2013, 10:50
Default 2D mesh extrusion and periodicity
robboflea is on a distinguished road
Hi all,
I am trying to extrude a 2D mesh with two periodic edges. The mesh works well in 2D. Periodicity is correclty specified and no errors are thrown out when doing the mesh check.
Once extruded everything looks fine, volumes, and boundaries are correctly associated to the right parts.
However when checking for periodicity issues in the mesh check the heck fails because several shells have no twin nodes.
The mesh check reports several messages like:
"shell 50676 has node 49901 which has no twin"
What can I do? Is there another way other than manually assigning periodicity in the mesh nodes which is simply impossible due to the huge amount of nodes in the periodic faces?
Thanks a lot
Rob
robboflea is offline   Reply With Quote
Old   August 31, 2013, 16:34
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
can you post some pictures that illustrate the vertices of your blocking that must have the periodic boundary condition?
regards.
diamondx likes this.
cesarcg is offline   Reply With Quote
[ICEM] 3D mesh of airfoil from 2D (segmentation violation) TKE ANSYS Meshing & Geometry 4 October 20, 2013 08:07
2D MESH actone CFX 5 October 27, 2006 10:59
