[ANSYS Meshing] Inflation Layers around a 90 degree bend that is separated into multiple parts
Like Tree1Likes
  • 1 Post By Kaaji1359
Old   August 16, 2013, 17:24
Default Inflation Layers around a 90 degree bend that is separated into multiple parts
Jeff
Kaaji1359 is on a distinguished road
I can't seem to find a solution to this, but basically I have a 90 degree bend in my part. For better edge sizing control, I split up the part into separate "fluid" domains using DesignModeler slicing commands, then combined the separate "fluid" domains into a single Part so that the edges are uniform.
However, when applying inflation layers to this 90 degree bend, the inflation layer doesn't go around the 90 degree bend (due to it having 3 separate "fluid" bodies); if I don't separate the body, then inflation works, but I lose edge sizing control. See attached picture for example.
It seems like an easy thing to do and it's odd that it's taking me this long to find a solution. Does anyone know of a way to fix Inflation around a 90 degree bend consisting of multiple parts??
Thanks in advance
Takue likes this.
Kaaji1359 is offline   Reply With Quote
Old   August 17, 2013, 09:17
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you are subdividing the body in order to give yourself edge control...
Put the cut on the 45 degree angle (a miter cut)
Or don't cut the model and use the prism settings to control the inflation.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   August 18, 2013, 19:57
Jeff
Thanks for the reply! I don't think a 45 degree Miter cut would work for my model (although it is a good idea and might work for other models)!
I guess I'll just have to either not cut the geometry into parts or imprint a line onto the geometry using DesignModeler. I'm assuming printing a line onto a 3D Fluid geometry wouldn't be too difficult?
[Workbench] Assigning Material to Multiple Parts dkx209 ANSYS Meshing & Geometry 4 February 1, 2023 03:00
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 13:11
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Creating inflation layers for elbow with airfoil ! Aplus CFX 1 March 13, 2006 23:22
