August 11, 2013, 11:07 |
mesh the static mixer
raha
Rep Power: 14 |
Hi
I want to mesh a static mixer like what you see in picture with t-grid method i create the geometry in solid work and then import to gambit but i have some problems in meshing is there anyone to help me? when i subtract 2 volumes to obtain flow domain i face with problem is this true : first mesh the surfaces of mixer and then mesh the flow volume ? thanks in advance |
August 12, 2013, 06:06 |
Maxime Perelli
Rep Power: 41 |
and what is the problem?
In memory of my friend Hervé: CFD engineer & freerider |
August 12, 2013, 10:57 |
raha
Rep Power: 14 |
My problem is that I cannot subtract two volume to create flow region because I face this error : cant operate on volume v_volume.6 with associated non-real geometry
and when I try to convert v_volume.6 to real I face this error : only faces with mapped mesh can be converted to real |
August 13, 2013, 01:38 |
Maxime Perelli
Rep Power: 41 |
*open new session
*import your solidwork files *check if imported volumes are real *if yes do the substract operation now
August 31, 2013, 07:18 |
Rick
Rep Power: 27 |
In the past I simulated the same type of static mixer; my approach in building geometry was:
- autocad for internals, very easy with the "twist" command - import into gambit exported .sat file - build into gambit the cylinder, with a diameter slightly smaller than the diameter of the internal - volume split operations to cut smaller volumes of internals, external to the cylinder - subtract operation to have the fluid volume You can directly mesh the volume with tetra, or if you want to control your mesh you have to mesh faces first. Daniele |
mesh, static mixer, tgrid |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
