[ANSYS Meshing] Export mesh ( .msh) in a ASCII format |
July 15, 2013, 12:16 |
Pedro Ramos
Rep Power: 14 |
Hello!
I'm trying to convert a Fluent mesh to an OpenFOAM one. The problem is that the mesh has to be in a .msh ASCII format and not in binary. Can any of you help me? I don t find anythinh in Fluent about this. Best regards. |
July 18, 2013, 11:59 |
Adrian
Rep Power: 14 |
If you have ICEM, you can import it from ANSYS meshing and then re-export it in the Fluent format needed to convert in openFoam.
www.idacireland.com |
July 18, 2013, 12:21 |
Pedro Ramos
Rep Power: 14 |
Hello, thank you for your answer.
Your suggestion seems good but the problem is that i don t find the option to export to a fluent file (.msh). See for yourself in here: http://d.pr/i/tqSz |
July 18, 2013, 12:28 |
Adrian
Rep Power: 14 |
Hi Pedro,
I can't see anything in that image link you've sent me.
July 18, 2013, 12:30 |
Pedro Ramos
Rep Power: 14 |
I'm sorry. And here:https://dl.dropboxusercontent.com/u/...5/Untitled.png ?
July 18, 2013, 12:38 |
Adrian
Rep Power: 14 |
Instead of exporting it from there, go to the output tab and click 'write input'. Choose ANSYS Fluent from there and it should write it in ASCII format.
July 18, 2013, 12:49 |
July 18, 2013, 13:10 |
Pedro Ramos
Rep Power: 14 |
ok, thanks. no i have this message error:
Usage: fluent3DMeshToFoam <Fluent mesh file> [-cubit] [-scale scale factor] [-ignoreCellGroups cell group names] [-case dir] [-ignoreFaceGroups face group names] [-help] [-doc] [-srcDoc] --> FOAM FATAL ERROR: Wrong number of arguments, expected 1 found 0 FOAM exiting |
July 18, 2013, 13:15 |
#9 |
I am not expert in foam, so I dont have idea about the error message.
http://openfoamwiki.net/index.php/Fluent3DMeshToFoam http://www.cfd-online.com/Forums/ope...eshtofoam.html http://www.cfd-online.com/Forums/ope...meshing-other/ |
July 18, 2013, 13:16 |
#10 |
Pedro Ramos
Rep Power: 14 |
ok, thanks a lot
October 6, 2016, 21:46 |
#11 |
Skanner Darkly
Rep Power: 10 |
In Ansys15 Mesher, I had to go to Tools->Options->Export and select ASCII (after I set the environment variable)
October 12, 2016, 06:26 |
#12 | |
Paritosh Vasava
Rep Power: 22 |
There is another way to bring fluent mesh to openFoam. Import your mesh to fluent and write case (no need to setup anything). While Writing the case make sure to remove tic in the binary option. Removing the tic will write the fluent case in ASCII form. This case file can be converted to openFoam mesh with fluentMeshtoFoam command. |
July 5, 2019, 04:08 |
#13 | |
Works perfectly in 2019 :-) thanks
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
July 29, 2019, 06:59 |
#14 | |
Yoann Di Maiolo
Rep Power: 7 |
Thank you so much
June 20, 2020, 12:30 |
#15 | |
mukund
Rep Power: 6 |
ascii. fluent, mesh |
[Other] ANSYS to Fluent mesh export in ASCII format | johannes | ANSYS Meshing & Geometry | 64 | October 19, 2021 20:13 |
[ICEM] export hexa mesh to fluent | Wieland | ANSYS Meshing & Geometry | 37 | January 23, 2013 03:27 |
Export mesh from Fluent in Nastran format | Wieland | FLUENT | 9 | October 19, 2012 09:16 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
