[ANSYS Meshing] Impeller Meshing
Like Tree1Likes
  • 1 Post By rvl565
Old   July 7, 2013, 15:26
Default Impeller Meshing
RacMat
rvl565 is on a distinguished road
I am trying to mesh an impeller using ansys meshing.
Whenever I use the advanced size function: On Proximity and Curvature, it gives the following error: "A software execution error occurred inside the mesher. The process suffered an unhandled exception or ran out of usable memory."
It works fine when I use the On Curvature setting.
I plan to use the MRF method.
The geometry was imported from solidworks as two seperate objects (.sat file) and i used the design modeller to subtract the impeller from the fluid region.
The same error also occurs when I use the patch independent Tetrahedron method. The On curvature setting works only when i use the Automatic Method.
A previous post suggested that i clear the generated data before meshing again, that didnt work for me.
Thanks for you help!
terrykim likes this.
rvl565 is offline   Reply With Quote
Old   July 24, 2013, 04:33
Verona
Giulio_ska is on a distinguished road
Did u find any solution? I have the same problem...
Tnx
Giulio
Giulio_ska is offline   Reply With Quote
Old   July 24, 2013, 09:02
Paritosh Vasava
vasava will become famous soon enough
Originally Posted by rvl565 View Post
I did not understand this.
If you importing or meshing geometries in parts for MFR it would not work.
vasava is offline   Reply With Quote
Old   July 24, 2013, 09:16
Paritosh Vasava
The memory error could be due to the fact that your computer does not have enough memory to generate mesh for your case.
When you use Proximity and Curvature for meshing, the mesher tries to refine the mesh in the regions where higher gradients are anticipated. If you do not mention the mesh size and leave it to the mesher it take some default values. The mesher will then try to refine your local mesh as much as possible. Now this may be useless and unnecessary. Sometimes to achieve a higher order of refinement the mesher has to spend very long time for refinement.
Old   July 24, 2013, 14:24
RacMat
Thanks for answering. you were right, my computer didn't have enough memory, i have solved the problem now.
Why would importing geometries in parts not work?
I had 3 parts, impeller, impeller fluid and the casing.
I subtracted the impeller from the impeller fluid and made an interface between the casing and the impeller fluid region. Is this wrong?
I have a thread regarding this http://www.cfd-online.com/Forums/flu...eneration.html
is this approach wrong ( the last post )?
Old   July 25, 2013, 02:34
Paritosh Vasava
Your approach is right. I meant that if you import geometries one-by-one it wont work.
Anyways its good that its working now.
Old   July 29, 2013, 17:20
RacMat
Thanks for the answers!
advanced size function, design modeler, impeller
[ICEM] Meshing Centrifugal Impeller Bellmo ANSYS Meshing & Geometry 8 November 27, 2018 14:02
[ICEM] Hexa meshing of impeller and diffuser assembly Nitin Dewangan ANSYS Meshing & Geometry 14 September 13, 2016 10:41
how to start for modelling n meshing a mixing tank with impeller jeevan ANSYS Meshing & Geometry 9 July 16, 2013 08:06
Dynamic meshing of impeller using fluent shadyenany FLUENT 6 September 22, 2011 17:56
[ICEM] Meshing a centrifugal compressor impeller Mitpostdoc ANSYS Meshing & Geometry 8 February 25, 2011 11:51
