[ANSYS Meshing] creating coupled boundary condition to examine conjugated heat transfer
Like Tree2Likes
  • 2 Post By rasekh64
Old   May 27, 2013, 09:37
Default creating coupled boundary condition to examine conjugated heat transfer
Alireza
rasekh64 is on a distinguished road
Dear all,
I am going to simulate convective heat transfer between fluid and solid parts in ansys-fluent. I have to do meshing in Ansys-mesher. In case of generating mesh in Gambit, I don’t have any problem as I can define connection between solid and fluid interfaces so that fluent consider one surface as a shadow wall. However, I am a bite confused working with ansys mesher. In fact, it also creates connection between fluid and solid part automatically, but surprisingly fluent doesn’t consider one of the walls as a shadow-wall so I am unable to define coupled boundary condition.
I would be more than happy if anybody help me to solve this problem.
Best,
Alireza
rasekh64 is offline   Reply With Quote
Old   June 3, 2013, 12:01
Ftab
ftab is on a distinguished road
Hi Alireza,
Why don't you simply change them to interfaces and then defining the mesh interfaces (the option bellow the BC) in the main menu, select the option for coupled wall.
I do not know it is a valid action, but if Fluent considers them as COUPLED WALL, it is exactly what you want to do.
ftab is offline   Reply With Quote
Old   June 5, 2013, 17:29
Alireza
hi,
I already found the solution. In order to assess the conjugated heat transfer between two surfaces, one should integrate two parts as a one body in the Ansys design modeler!
I am afraid the way you recommended doesn't work.
thanks in advance,
Alireza
Originally Posted by ftab View Post
Hi Alireza,
sk333bits and dara like this.
Old   March 13, 2014, 10:13
thermal energy is on a distinguished road
hello dear friends,
ı have a question about coupled boundry condition. ı need help. thank you. good work.
Should i activate coupled option for both wall and wall-shadow, for each side of the two-sided wall?
thermal energy is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
Wall boundary condition (heat transfer) Arnold FLUENT 4 February 16, 2006 23:35
boundary condition for Heat Transfer sylvain Main CFD Forum 4 June 30, 2005 16:26
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
