[Workbench] Meshing stirred tank
Like Tree1Likes
  • 1 Post By Shaafi
Old   May 3, 2013, 12:54
Post Meshing stirred tank
Shaafi is on a distinguished road
Hi! all
Iam currently doing a case where i want to simulate a stirred tank reactor. The tank reactor is quadratic in shape and have an impeller in the center. Iam using Multiple reference frame (MRF) for the rotational region. However i have some difficulties with the meshing i would want a hexahedral mesh in the tank and a tetrahedral mesh in the cylindrically shaped rotational region. Which meshing method is most suitable for this? and how can it be done? iam kinda stuck on this part and i would really appreciate some help. I will attach some images of the geometry for visualization.
Thanks in advance
Regards Shaafi
ArturF likes this.
Shaafi is offline   Reply With Quote
Old   May 4, 2013, 10:07
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Hi
Which mesh generation software you are using for your case?
Far is offline   Reply With Quote
Old   May 4, 2013, 10:17
Hi!
Iam using workbench fluent meshing application
Kind Regards Shaafi
Old   May 4, 2013, 10:28
Far
Sijal
Tgrid, ansys meshing or Gambit?
Old   May 4, 2013, 10:33
Sorry about that i meant the ansys meshing
Old   May 4, 2013, 10:34
Far
Sijal
did you take a look on similar cases at ansys meshing and geometry forum?
Old   May 4, 2013, 10:39
yes i did i made the ansys tutorial on stirred tank but the geometry in the tutorial was for a cylindrical shaped tank and i tried to apply the same meshing method(Sweep meshing) by decomposing my geometry with slicing approach so the geometry could more easily be swept but unfortionally it didnt work, and i have no clue how to go on from this point
[ANSYS Meshing] stirred tank meshing jamalf64 ANSYS Meshing & Geometry 16 April 20, 2013 17:00
Meshing stirred tank with gambit. boh_tea FLUENT 13 March 29, 2013 14:29
Meshing of a stirred tank reactor Ajayi Olukayode FLUENT 8 October 3, 2012 03:24
Gambit Meshing of stirred mixing tank shadyenany FLUENT 4 September 15, 2011 13:13
meshing of stirred tank - hexa vidhya Main CFD Forum 0 April 21, 2011 04:20
