April 10, 2013, 16:18 |
Grid dependency study
Elina Mathew
Rep Power: 13 |
Hi Friends
I have a fluid flowing over a cube of metal..and I have to mesh them in such a way that I have very less number of elements on both zones say upto 10,000 and I have to do grid dependency study...So can someone help me how to do that and also is it possible to mesh the fluid zone alone and solid zone alone..?? Kindly help me.... |
April 10, 2013, 18:34 |
Astio Lamar
Rep Power: 14 |
Hi!
You can mesh them separately and in the solve you should define mesh interface. To to this divide the geometry in two parts, (solid and fluid) in each delete the other part, generate the mesh. For instance for the fluid one, delete the solid part of the geometry and just mesh the fluid part and vise versa. |
April 11, 2013, 08:10 |
Elina Mathew
Rep Power: 13 |
Hi Asal
Sorry I dint get you...Is it possible to do like that..?? so I have to create two meshing module and then connect both of them into one Fluent setup module or what..?? See the problem is I have a solid cube and above it fluid is flowing....And the thing is I have to mesh both and also if possible structured meshing...and very less number of elements...so how can I delete one part..u mean to suppress one part and do for the other..?? but in the setup module of fluent how will both mesh come together...??? And what will be the interface I have to give..???Thanks a lot... |
April 11, 2013, 08:41 |
#4 | |
Tarantino
Rep Power: 13 |
see here and follow the instruction. http://jullio.pe.kr/fluent6.1/help/html/ug/node1157.htm |
What is meant by Grid Independence Study? | Khan | FLUENT | 10 | July 2, 2015 23:40 |
Question about grid independence study | Anna Tian | Main CFD Forum | 4 | October 25, 2012 15:13 |
Question about the grid independance study | Anna Tian | CFX | 1 | September 16, 2012 08:41 |
Problem with Grid convergence study | dialolema | CFX | 1 | June 14, 2010 19:33 |
About grid sensibilty study | Fabio | Main CFD Forum | 0 | October 15, 2009 12:23 |
