[ICEM] how to execute structured mesh in Ansys ICEM 14.0
Like Tree2Likes
  • 1 Post By diamondx
Old   April 10, 2013, 09:29
Default how to execute structured mesh in Ansys ICEM 14.0
saurabh mangal
lucky_m_m is on a distinguished road
Hi everyone,
I am novice to ansys 14.0 meshing. I want to execute a structured mesh for a circular plane. the type of meshing I want to generate is attached. I am able to genrate same mesh in gambit pre processor. I am not able to use virtual topology.
Please guide me in detail or provide me tutorial for the same.
lucky_m_m is offline   Reply With Quote
Old   April 10, 2013, 12:28
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it is very easy to achieve in ICEM CFD... are you interested in using icem cFD ?
lucky_m_m likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 11, 2013, 05:17
saurabh mangal
Hi Ali,
Thanks a lot for the reply. Yes, I want to do it in ICEM CFD Tetra Mesher provided by Ansys 14.0 package.
Old   April 11, 2013, 05:18
saurabh mangal
Originally Posted by lucky_m_m View Post
Hi Ali,
Help and guide me. I will be grateful. I am very much interested in this field and my research can reach to next level if I learn this.
Old   April 11, 2013, 12:17
diamondx's Avatar
Ghazlani M. Ali
this videos will explain better than me : http://www.youtube.com/watch?v=T2Dxa0OZf58
Regards,
Ali
Old   April 12, 2013, 06:53
saurabh mangal
Thanks a lot Ali,
I also have another doubt related to connectivity of the mesh of different zones in a body. I am working on a two phase model of air and water using VOF in fluent. In water I need a simple hexa mesh with same element size but in air at the interaction the mesh elements chould be small and it increases as I go farther.
I know the mesh is to be connected for the analysis. So in Geometry modelling in Ansys 14.0 do I need to model water and air in the same part or they can be different parts also.
Regards,
Saurabh Mangal
Old   April 12, 2013, 10:25
diamondx's Avatar
Ghazlani M. Ali
put them in different part. after outputting to fluent you will have something like int_air and "int_water". it will be easy for you to distinguish between the two and initialize
Regards,
Ali
Old   April 12, 2013, 11:00
saurabh mangal
but then the mesh is not connected.
Old   April 12, 2013, 11:33
diamondx's Avatar
Ghazlani M. Ali
you started with one block right ? then you performed splits... after the splits, you get multiple blocks. you need to name one block AIR and other block WATER. they will still be connected
Regards,
Ali
Old   April 12, 2013, 11:41
saurabh mangal
yes I did it that way only. But the mesh I create some elements are not connected.
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
Structured mesh in ICEM for rectangular channel Josh ANSYS Meshing & Geometry 5 March 12, 2010 15:53
Error Converting ICEM Structured Mesh to CFX Chebeba CFX 11 October 5, 2006 09:05
ANSYS ICEM CFD smoothing mesh corner chamfered Hans CFX 4 January 26, 2006 17:00
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
