[ICEM] How to run ICEM over parallel processor?
Like Tree1Likes
  • 1 Post By davidwilcox
Old   April 4, 2013, 12:07
Default How to run ICEM over parallel processor?
Astio Lamar
asal is on a distinguished road
Hello!
I want to run ICEM over parallel processing. I follow the path "Settings => General => number of processors" to assign number of the processors which I want to used by ICEM. But it doesn't work and still ICEM used just one processor.
Any idea about this issue?
asal is offline   Reply With Quote
Old   April 4, 2013, 12:50
AB
BrolY will become famous soon enough
It's not a bug, ICEM can use more than 1 proc only for some operations, not all the time.
BrolY is offline   Reply With Quote
Old   April 4, 2013, 13:44
Astio Lamar
Hi!
What do you mean by some operations?
Why not for the all? And what is those operations?
Thx.
Old   April 4, 2013, 14:53
david
davidwilcox is on a distinguished road
what is it exactly that you wanna do with the multiple processors?
davidwilcox is offline   Reply With Quote
Old   April 4, 2013, 15:23
Astio Lamar
Since I have huge number of node in a geometry, after each modification, it takes a very long time to see check the quality and/or mesh preview. ICEM just use one processor out of 12 (around 7%). So if it run over the whole, then I got much more speed.
Old   April 5, 2013, 16:51
david
i am checking with the ANSYS people in Calgary and hopefully they will give me a reply
asal likes this.
Old   April 8, 2013, 04:17
Astio Lamar
Hi!
Since I ask for the answer and I got reply, I want to share it with the others.
Only the volume meshing using the Octree approach can take advantage of the parallel option in ICEM!
Old   April 8, 2013, 15:19
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
In fact octree is the most resource consuming method.
Far is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
error in parallel run immortality OpenFOAM Running, Solving & CFD 7 January 1, 2013 14:35
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
