[ANSYS Meshing] Unable to create inflation layer (with picture)
Like Tree1Likes
  • 1 Post By PSYMN
Old   March 13, 2013, 17:41
Question Unable to create inflation layer (with picture)
René
rene78 is on a distinguished road
I would like to inflate a simple rectangular tube profile (30x15mm). I played around with all the inflation settings, but nothing works.
If the options "show program controlled inflation surfaces" is selected, no geometry is highlighted. So obviously this geometry cannot be inflated. But why?
Any ideas what I'm doing wrong?
PS: If somebody could tell me how to create this "extruded 2D mesh by one element" in V13 - that would be even better!
rene78 is offline   Reply With Quote
Old   March 13, 2013, 18:03
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Did you try to add an inflation to the sweep method?
You can find it either in the options of the sweep method or right-click on it and choose inflate this method.
flotus1 is offline   Reply With Quote
Old   March 13, 2013, 18:21
René
"Inflate this method" is only available, if the source and/or target selection is set to "manual" when defining the sweep method. But then the mesh looks distorted.
But you're right. This way it works:
Old   March 14, 2013, 09:06
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, sweep requires you to setup the inflation (doesn't use program controlled). But Multizone might be another option. Did you give that a try?
rene78 likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 14, 2013, 17:09
Thumbs up Solved
René
Hi Simon, Multizone worked pefectly, thanks!
cfx-mesh, inflation
[ANSYS Meshing] Inflation layer / Element quality Spookz ANSYS Meshing & Geometry 17 February 12, 2019 05:55
[snappyHexMesh] SnappyHexMesh AddLayer Control rdrr84 OpenFOAM Meshing & Mesh Conversion 28 May 30, 2014 06:32
sample interpolation error in inflation layer eelcovv OpenFOAM Bugs 2 July 28, 2009 18:20
how to create boundary layer in icem cfd? jayesh CFX 3 November 24, 2005 10:00
