[ICEM] Importing mesh to fluent
Like Tree5Likes
  • 1 Post By stuart23
  • 2 Post By stuart23
  • 1 Post By PSYMN
  • 1 Post By arunintn
Old   March 13, 2013, 12:14
Question Radiator boundary condition
Arun
arunintn is on a distinguished road
we are doing a supersonic flow on jet aircraft and use radiator to make a thermal expansion to show engine out but when i import the mesh in to fluent it is not reorganizing the radiator and it is changing to wall.
the error we have:
Building...
mesh
Warning: Inappropriate zone type (jump) for one-sided face zone 13.
Changing to wall.
materials,
interface,
domains,
zones,
sym
Pff
v-tail
wing
intaked
jet
Error: Cannot change radi to fan because
there is only one adjacent cell thread.
Error Object: #f
radi
int_fluid
fluid
Done.
My question is
why? I have this error and the reason.
what? I need to do to solve this error.
Can someone help me in this please.
arunintn is offline   Reply With Quote
Old   March 13, 2013, 20:59
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
A porous jump is a mesh surface that is connected to volume mesh on both sides. The surface in the mesh you are trying to import does not not have volume mesh on both sides.
Stu
arunintn likes this.
stuart23 is offline   Reply With Quote
Old   March 14, 2013, 04:35
Exclamation problem on merging surfaces
Arun
Thank you Stuart.
I have one more problem now. after i change the block to surface i can not mesh it. i attached the picture.
i tried to mesh by part and it is saying there is a hold.
(http://www.cfd-online.com/Forums/ans...nt-repair.html)
i tried to do the edit mesh to close hole but it is not working in final mesh.
can i have the solution that i can use to make it work. I'm trying in different method but still now i did't get it done.
Old   March 14, 2013, 09:20
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
So is the porous jump that thin gap? If so, do you have curves around the perimeter on both sides? Your edges look rather sloppy. If you have curves and it is still messy like that, you would need to use a smaller mesh size to capture the gap or apply something like "Thin Cuts" between the closely spaced walls.
If the porous region is really the larger area to one side of that gap and the gap is just a badly fit geometry, then just delete the curve and surface that is not needed so the mesh can walk over it.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 14, 2013, 12:50
Arun
Thank you simon,
sorry for the confusion.
The above post i added two picture.. the first pic is to show the error i found and the second is the problem.
as you suggested i did editing the curves and surface. but it is not meshing on the radiator surface. I added the detail picture now. please i like to know the reason. why it is not meshing that part alone?
Old   March 14, 2013, 18:55
Stuart Buckingham
Are you using Octree? Set the interface as an internal wall
PSYMN and arunintn like this.
Old   March 14, 2013, 20:37
PSYMN's Avatar
Simon Pereira
Oh, I see. I thought the purple surface was a patch on the outer surface of the duct...
Yes, if it is an interior wall and it has the same volume material on either side, OCTREE will assume it is just junk and remove the elements unless you flag it as an internal wall. (Mesh (tab) => Parameters by parts and check the box for internal wall on that part).
Stuart got it right.
Old   March 15, 2013, 04:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Stuart in action. Stuart you doing good at LEAP.
Far is offline   Reply With Quote
Old   March 15, 2013, 07:40
Stuart Buckingham
Haha, how do you know where I work? You're not a spy are you!?
Old   March 15, 2013, 07:46
Far
Sijal
LinkedIn : You are in my connections
Old   March 15, 2013, 08:14
Stuart Buckingham
Of course!
Old   March 15, 2013, 12:02
Thumbs up solved
  #12
Arun
at last i have it is solved. really it is a very simple thing that i did't learn for a long time thanks for helping me Stuart and Simon.
I'll come with more question in the next meshes..
And Ahamed good to see you at last
Far likes this.
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) Joachim ANSYS 3 April 24, 2016 17:52
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 03:22
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
A error about importing Gambit mesh to Fluent. shin FLUENT 3 November 19, 2002 03:09
