[ICEM] The problem about transferring SOLIDWORKS 2D geometry file to ICEM |
February 7, 2013, 08:21 |
Rep Power: 14 |
Hello, I'm a beginner using ICEM CFD & FLUENT ANSYS.
When I use ICEM to meshing, the geometry should be imported from CAD program. CAD program I use is SOLIDWORKS(ver.2010). In case of 3D, the geometry is imported easily by 'workbench reader', but the 2D case does not work(although I add a plane to 2D geomtry). (the error message) Error: File not found Current Coordinate system is global Transferring 2D geometry doesn't work from Solidworks to ICEM, originally? |
March 30, 2013, 11:59 |
Rep Power: 13 |
Try to save your geometry in .igs (iges) ad import it into icem
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
[ICEM] The problem about transferring SOLIDWORKS 2D geometry file to ICEM | meshman | ANSYS Meshing & Geometry | 0 | February 5, 2013 23:38 |
[ICEM] Problem while improting Solidworks Part file or Acis File into ICEM CFD | venki1130 | ANSYS Meshing & Geometry | 0 | October 13, 2011 14:04 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
