[ICEM] surface boundary doesn't match the curve
Like Tree1Likes
  • 1 Post By BrolY
Old   January 17, 2013, 11:02
Default surface boundary doesn't match the curve
motorbean
motorbean is on a distinguished road
Attachment 18258Hi, everyone, I have a problem.
I plan the segment the surface with the curves that forms the shape of the blade. But after the segmentation and deletion of the surface inside the blade, I found that the surface boundary doesn't match the blade curve, especially at the leading edge, as shown in Fig 1. Can anyone tell me why and how to let the surface match the curve please?
By the way, I've set the overall topo tolerance as 3e-4 and triangular tolerance as 1e-8, but the problem persists.
Thank you very much!
motorbean is offline   Reply With Quote
Old   January 17, 2013, 11:42
AB
BrolY will become famous soon enough
The option Segment surface doesn't work all the time .. I've been using this tool for years, and the way it works is still a mystery for me ...
1) you need a very good surface to use this tool.
2) be sure the curves with which you want to segment the surface are attached to that surface.
If it doesn't work, you can also try Geom -> Create/modify curve -> Project curve on surface (don't forget to select the option "trim surfaces). Sometimes it works.
Otherwise, try to redo your surface .. or redo the curves (by intersecting 2 surfaces for example) ..
Sometimes, just close and reopen ICEM ..
Good luck
BrolY is offline   Reply With Quote
Old   January 17, 2013, 11:51
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It may be Visual artifacts. Make the mesh and see if it follow the surface and curve properly.
Far is offline   Reply With Quote
Old   January 17, 2013, 11:53
AB
Did you turn on the option "Show full" of your surfaces ?
If not, Far is right.
If yes, good luck
Dronzer likes this.
Old   January 17, 2013, 12:47
motorbean
Thanks, guys! I turn on "show full" and it works!
Also, I've found another way to do the segment: Repair Goemtry->Build Diagnostics Geometry. Then build from the curves and the surface.
After that, the curves will trim the surface, and they are associated to the surface as well! This is useful if you are going to do an unstructure mesh, and useful for automatic meshing.
Old   January 17, 2013, 12:55
Far
Sijal
Yes Build topology is awesome tool and it do many tasks in automatic fashion like attaching curves and points to respective surface, subtract the surface at the intersection with another surface and trim when necessary.
Build toplogy tool is pre-requisite for the tetra mesh.
Old   January 17, 2013, 15:11
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Good luck
I tought i was not good at using that feature, i guess i m not the only one. i rely too much on the build topology with checking the option split surface...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 21, 2018, 04:53
Thumbs up Thanks
Dronzer's Avatar
Dronzer is on a distinguished road
If yes, good luck
Thanks!
I was about to export my model to another CAD software to repair it .
Dronzer is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
Boundary condition of free surface model Tony FLUENT 3 September 27, 2004 14:48
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
