[Other] Importing Multiple Meshes
Like Tree1Likes
  • 1 Post By Far
Old   December 13, 2012, 09:56
Question Importing Multiple Meshes
Felix
Spookz is on a distinguished road
I have got two domains. I want to mesh the one domain with ICEM CFD and the other one with the cfx mesher.
Then i want to import the created meshes in Ansys cfx. The Cfx Pre User Guide says that i can import multiple meshes by right click on the mesh branch in the tree view / Import mesh and then multiselect the mesh files by holding CTRL-key. But actually this doesn't work. It just lets me select one mesh-file.
How is it possible to import more than one mesh in a cfx-module?
Thanks in advance!
Spookz is offline   Reply With Quote
Old   December 15, 2012, 16:49
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There are many methods to do this.
The simple method:
1. Make a new case > General > Ok
2. In the left panel, right click on mesh > Import mesh> select mesh type (e.g. ICEM, CFX etc)
3. Again right on the mesh and import the mesh
4. Set-up the boundary conditions as appropriate.
Far is offline   Reply With Quote
Old   December 17, 2012, 05:51
Felix
Ok thanks this works.
But when i import the second mesh, this mesh is quite bigger (factor of 1000), though the models come from the same CAD-part file and in ICEM the length units (right-click on model/geometry units) are both on mm.
Am i still doing something wrong?
Old   December 17, 2012, 07:47
Far
Sijal
change the units while importing the mesh which has problem or right click on problem mesh and then go to transform and change the units
brenohc likes this.
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Exporting Multiple Meshes to Fluent anksta FLUENT 3 May 5, 2009 09:07
Multiple Moving Meshes Animation Tristan CFX 3 March 19, 2009 20:14
