[ANSYS Meshing] How to insert a interior surface mesh
Like Tree1Likes
  • 1 Post By jrunsten
Old   December 4, 2012, 09:19
Default How to insert a interior surface mesh
JJ Perez
jjperez is on a distinguished road
Hello I'm a new user of ANSYS. Someone know how I can insert a interior surface mesh in a geometry? I must put the surface in the Designmodeler module or in the Ansys Meshing ?(these surface is a green surface inside the geometry, I attached a image to help you). I want make that to use these surface like a fan in a building ventiltion simulation.
Thank you.
jjperez is offline   Reply With Quote
Old   December 4, 2012, 10:06
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
create a plane there, draw your circle using sketch, then go to concept -> surface from edges (or sketch) and you will get it...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 4, 2012, 10:32
JJ Perez
Hello Diamondx, i tryed that in Designmodeler, but when I try to mesh the created surface in ANSYS Meshing doesn't work and I can't mesh the geometry. I need put a value for the tickness of the created plane or configure specially these plane?
Thank you again!
Old   December 5, 2012, 09:30
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
If you split (Slice) the cylinder you will automatically get an interface between the two halves. Just make sure the body is Frozen before you do so
Far likes this.
jrunsten is offline   Reply With Quote
fan, fan boundary condition, interior surface
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
