[ANSYS Meshing] Workbench Meshing Tool - Max Face Size Parameter
Like Tree1Likes
  • 1 Post By uniepedrsantos
Old   November 13, 2012, 09:54
Default Workbench Meshing Tool - Max Face Size Parameter
Max
MaxHeat is on a distinguished road
Hi everybody,
I am building a mesh using the ANSYS workbench meshing tool. When I try to specify the element size, I find a parameter-option called "Max Face Size". Does anybody know for what this value stands for?
First I thought it stands for the maximal face size of the biggest element, but the dimension of the parameter is one-dimensional. Using the ANSYS help does not really help me since it defines the parameter as the diagonal of a certain bounding box with no further explanation what that bounding box is.
Regards,
Max
MaxHeat is offline   Reply With Quote
Old   November 13, 2012, 11:29
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
if it's one dimensional, it should be the length of the face... i guess
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 18, 2014, 15:54
Pedro
uniepedrsantos is on a distinguished road
I found this question here in this ANSYS's tutorial.
- Min Size: the minimum element edge size that the mesher will create.
– Max Face Size: Maximum size the surface mesher will allow.
– Max Size: Maximum size the volume mesher will allow.
– Growth Rate: Specifies the increase in element size for each succeeding layer
progressing from an edge. A value of 1.2 represents a 20% increase. Settings
from 1 to 5 with a default determined by relevance and transition settings
follows the link:
http://inside.mines.edu/~apetrell/EN...ME442_lab3.pdf
charannath likes this.
uniepedrsantos is offline   Reply With Quote
Old   March 2, 2021, 08:50
Ngele Celestine
ngelecc@gmail.com is on a distinguished road
Greetings guys! Please can someone explain what is "Bounding Box" in ANSYS for me! Thanks!!!
ngelecc@gmail.com is offline   Reply With Quote
Error message: 8 face(s) not in face lists of adjacent cells jyoung79 FLUENT 0 November 10, 2012 17:09
Force can not converge colopolo CFX 13 October 4, 2011 23:03
[ICEM] Meshing Size Problem eRzBeNgEl ANSYS Meshing & Geometry 2 April 17, 2011 16:53
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
