[ANSYS Meshing] The mesh file exporter failed during translation.
Like Tree1Likes
  • 1 Post By ashraf88
Old   November 2, 2012, 15:42
Default The mesh file exporter failed during translation.
Guan
foolboy007 is on a distinguished road
Ansys WB 14.0 in university computer lab. not administrator.
I also ask the administrator to logon using admin account and try, still had following problem:
When I update the mesh cell of WB after generating mesh, I always got this error:
The mesh file exporter failed during translation. Please send your data to your support provider.
I got the same error when I export .msh file from meshing.
I copy the project files to my computer. Everything works fine.
It seems that the policy for active directory has something to do with the error. But we do not know how to modify.
foolboy007 is offline   Reply With Quote
Old   November 2, 2012, 15:49
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
may be no more disk space ??
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 2, 2012, 15:54
Guan
no, I tested with a very small mesh file. That was just a cube with very coarse mesh.
Old   January 24, 2013, 06:22
Default hope it helps
ASHRAF ALFANDI
ashraf88 is on a distinguished road
I encountered the same problem. This was because the file directory contained some foreign characters.
So check the file directory, make sure it does not contain any special characters.
coffee_break likes this.
ashraf88 is offline   Reply With Quote
Old   June 3, 2013, 03:23
Default for help
li haoran
hitlhr is on a distinguished road
Hi,,
I also met the same problem, could you tell me how do you solve it now? thank!
hitlhr is offline   Reply With Quote
Old   March 5, 2015, 11:11
Gürkan Sarikaya
gurkan is on a distinguished road
I encountered same problem, I have no special character in my directory file's name, even I tried to change file name and saved my work with "save as", but there is no change for error.
Are there anyone to solve this problem with different solution?
thanks,
gurkan is offline   Reply With Quote
Old   April 14, 2015, 12:16
Default Solution to this problem
Ed Moses
edmoses is on a distinguished road
Hi All,
I have also encountered this problem numerous times since version 14.0, and now, recently, in version 16.0.
I found a solution now. The mesh translator will accept export of any mesh created with Assembly Meshing, i.e. either CutCell or Assembly meshing tetrahedrons. I just did it yesterday and it worked. Enjoy.
edmoses is offline   Reply With Quote
Old   June 26, 2017, 18:57
Default Another Solution for This Problem
shreehan Abd El-Ghafour
sh.a.ghafour is on a distinguished road
Hi Dear
I have encountered this problem in my work also and i found that the method of creating one part in the DesignModeler is the cause of this error. for example if you create one part with the translation of another part, this may be the reason for this error in the meshing export. In Other words, the method which you used to draw the part is the cause for the error in meshing this part.
Best Regards
sh.a.ghafour is offline   Reply With Quote
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
