[ICEM] Is this blocking correct?
Like Tree2Likes
  • 1 Post By energy382
  • 1 Post By Far
Old   October 18, 2012, 04:27
Default Is this blocking correct?
cfd seeker is on a distinguished road
I blocked a very easy geometry 2D Flate plate inclined at 70 deg AOA for someone. After doing the blocking I put the O-grid around the plate and end up whats is attached in the post. Min quality is 0.8 which is very good but I am not sure about the associations and Ogrid in the neighbor hood of y-block. Kindly look at blocking and tell me if this is correct or how you would do it? Thanks
Regards
cfd seeker is offline   Reply With Quote
Old   October 18, 2012, 07:44
Christoph
energy382 is on a distinguished road
Regards
not sure, if I get your point exactly. But if you want to simulate a straight flow around a inclined plate, you don't need any o-grids or y-grids. I've attached blocking. You can adjust boundary layer etc. with edge params.
sorry, if I get you wrong. please give a feedback
Far likes this.
energy382 is offline   Reply With Quote
Old   October 19, 2012, 02:33
Thanks for your effort but what do you mean by straight flow?
Old   October 19, 2012, 03:03
nitin bansal
nitinbansal184 is on a distinguished road
attaching newly meshed 2d plate
nitinbansal184 is offline   Reply With Quote
Old   October 19, 2012, 11:08
really a great and simple blocking topology but can you explain how you did it? The only confusion is how you did tilted cuts? I only how to make vertical and horizontal cuts in ICEM
Old   October 19, 2012, 12:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
cfd seeker Blocking done by energy382 and nitin are similar. When you make the association the blocking changes its shape according to geometry.
nitinbansal184 likes this.
Far is offline   Reply With Quote
Old   October 19, 2012, 13:26
Thanks. Can you tell me how many cuts we have to make initially and at what locations according to the blocking of energy?
Old   October 19, 2012, 13:29
Far
Sijal
two horizontal and two vertical cuts
Old   October 20, 2012, 09:42
nitin bansal
Most probably I will publish some videos or some images about blocking procedure.......
Check it on Sunday
Is my Dynamic mesh setup correct? cfd seeker FLUENT 16 October 30, 2020 07:16
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 04:13
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 18:27
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 05:46
