[ANSYS Meshing] tolerance of geometry is large. How to reduce?
Like Tree1Likes
  • 1 Post By Farid
Old   October 15, 2012, 12:35
Default tolerance of geometry is large. How to reduce?
Guan
foolboy007 is on a distinguished road
I got a warning from ANSYS meshing:
The tolerance of the geometry is larger than the applied tessellation refinement tolerance. This might lead to an uneven mesh and/or to poor geometric accuracy of the mesh.
the min mesh size was 2e-5 so I can get y+~1.
the geometry was built in workbench DM.
is there a way to modify the default tolerance of the geometry?
foolboy007 is offline   Reply With Quote
Old   January 28, 2014, 13:17
Umberto is on a distinguished road
Did you manage to solve this problem eventually?
Umberto is offline   Reply With Quote
Old   May 19, 2014, 16:20
Farid is on a distinguished road
I ran into same problem and with refining mesh, it was solve.
Farid is offline   Reply With Quote
Old   January 21, 2015, 05:31
cfdan is on a distinguished road
refining mesh as in reducing local min size?
cfdan is offline   Reply With Quote
Old   January 23, 2015, 11:44
Sometimes it helps,
1. Click on the name of your geometry on the top of the modeling tree. -> Change "Model tolerance" to "Tight".
2. For curvatures tone "Facet qualities" to higher value.
hazimhalimi likes this.
Old   February 24, 2015, 00:31
muhammad hazim bin mohd halimi
hazimhalimi is on a distinguished road
i cant find the model tolerance settings (note that i am using ansys fluent).
can you guide me to solve the proposed problem?
"The tolerance of the geometry is larger than the applied tessellation refinement tolerance. This might lead to an uneven mesh and/or to poor geometric accuracy of the mesh."
hazimhalimi is offline   Reply With Quote
Old   February 24, 2015, 20:04
Originally Posted by Farid View Post
Sometimes it helps,
where can i find that option on ansys fluent?
Old   March 9, 2015, 11:02
I have no idea to change the tolerance in fluent. What I wrote in the previous post is for Design modeler. The tree outline of the geometry on the left hand side. Just click on the very first line. In table of details view, you would see "Model Tolerance"
Old   March 9, 2015, 13:04
i got it already. thank you farid.
i also fix the proximity angle and the tolerance is smaller and better.
Old   April 15, 2015, 11:12
khoibuivan
mipt_khoi is on a distinguished road
Could you post pictures of fixing this error? I don't find how to change Model tolerance. Thanks!
mipt_khoi is offline   Reply With Quote
Old   April 16, 2015, 14:56
i dint change the model tolerance.
i just reduce the Curvature Normal Angle.
steps:
mesh>sizing>curvature normal angle
Old   January 28, 2016, 14:49
Default changing geometry dimensions
  #12
Oula
Oula is on a distinguished road
Sometimes it helps,
Dear Fraid, your answer to this thread helped me alot. I have only one question to you. Does changing the model tolerance affect the geometry dimensions or any thing else?. I got issue that the dimensions of my geometry in fluent differ a lot. I have noticed that when creating plans
Thank you in advance for your helo
Oula is offline   Reply With Quote
Old   September 15, 2019, 04:17
Default Solution from ANSYS student community
  #13
vidyadhar
vidyadhar is on a distinguished road
I could solve the problem by setting the Tesselation Refinement value to "NONE" as mentioned in the post here: https://studentcommunity.ansys.com/t...n-refinement-/
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Large Epsilon 3D lepsilon Main CFD Forum 0 July 10, 2012 11:43
fvSchemes, Fina residual tolerance not working Attesz OpenFOAM Running, Solving & CFD 3 March 20, 2012 04:26
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
LES on a scaled geomentry (Mesh and Large scales) comb Main CFD Forum 0 February 8, 2011 07:21
stitchMesh for uncongruent patches (stitch tolerance) beugold OpenFOAM 0 June 18, 2009 08:38
