September 18, 2012, 03:55 |
Mesh Quality
Hamed Abdul Majeed
Rep Power: 14 |
What are the parameters used to test the mesh quality: I know a few such as aspect ration, expansion ratio, orthogonality angle. There is also this parameter CGI, kindly explain it. Add any other parameters that are important when reporting a mesh. Thank you Regards Hamed |
September 18, 2012, 11:01 |
Ghazlani M. Ali
Rep Power: 29 |
topic about mesh quality is discussed multiple time in this forum try searching the forum i'm sure you will find a lot.
Don't know much about cgi parameters, hope someone else can explain it. |
September 18, 2012, 12:12 |
#3 | |
There is very nice explanation of these parameters by Simon on this forum, search is the key |
September 18, 2012, 15:18 |
AHMED
Rep Power: 14 |
I think its GCI not CGI
September 19, 2012, 12:17 |
Simon Pereira
Rep Power: 47 |
The Help documentation should also include something for each metric, but I am not sure what metric you are asking about (GCI or CGI, I don't know of either). What tool are you looking in?
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
September 21, 2012, 23:23 |
Hamed Abdul Majeed
Rep Power: 14 |
It is the grid convergence index GCI. It is a factor to estimate discretization error based on Richardson extrapolation principle |
September 22, 2012, 03:09 |
Well it is the index of quality of CFD which you are performing. In other words, it is you who will decide that how much mesh size is needed to the asymptomatic behaviour. Whether it is 1 million, 10 million or even 100 million. ICEM will give you whatever you ask for.
September 22, 2012, 11:35 |
Hamed Abdul Majeed
Rep Power: 14 |
thnx for reply. I have another question. We place the 1st node from the wall based on y+ value and the formula 1st node distance is delta y = sqrt(74)*Re^(-13/14)*L*y+*L The value of y+ in above formula depends on the turbulence model used. My question is: Once 1st node distance is specified using above formula, what are the parameters that govern the selection of expansion ratio applied to the mesh. I mean what should the increasing gap of node be starting from the 1st node |
September 22, 2012, 12:40 |
#9 |
Simon Pereira
Rep Power: 47 |
Usually a ratio of 1.2 is used. But you could go higher or lower if you want the total height of your boundary layer to be less or greater.
The point is just to have enough mesh discretization to capture the boundary layer profile. That profile is changing faster near the wall and reduces as you move away. The ratio is just to reduce the number of nodes so you are not using the same resolution to capture less change.
September 22, 2012, 17:25 |
#10 | |
1. Use expansion ratio 1.2 at max and for transition critical flows lower values to 1.15 or 1.1 2. For fully turbulent flows you can use the Y+ upto 10, in that case you will have the 10-15 nodes in the whole boundary layer. You can find the boundary layer total thickness from the turbulent flat plate boundary layer formulae 3. Boundary layer gets thinner as Reynolds number increases and vice-versa Last edited by Far; September 22, 2012 at 17:38. Reason: Addition of Point # 3 |
September 23, 2012, 03:35 |
#11 | ||
Rep Power: 20 |
September 23, 2012, 03:48 |
#12 | ||
----------- For transitional flows (laminar to turbulent), you need Y+ less than 1 with other constraints. |
September 23, 2012, 03:55 |
#13 | |
Rep Power: 20 |
September 23, 2012, 03:56 |
#14 |
September 23, 2012, 04:06 |
#15 |
Rep Power: 20 |
mesh, mesh quality |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Polyhedral Mesh Quality in Star-CCM+ | niazaliahmed | STAR-CCM+ | 3 | March 8, 2012 14:51 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 23:04 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
