[ICEM] ICEM Meshing problem
Like Tree1Likes
  • 1 Post By diamondx
Old   August 21, 2012, 06:51
Exclamation ICEM Meshing problem
nitin bansal
nitinbansal184 is on a distinguished road
PLs help me with Correction of Meshing Quality.
I have tried Everything But Not able to reduce quality below 0.8 or 0.9
Below are attachment of block,geometry and prj file
Thanks
nitinbansal184 is offline   Reply With Quote
Old   August 21, 2012, 09:21
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
the minimum quality is 0.7. which is very good. not need worry about it. i don't know why you need a better quality. all i can say is that the blocking strategy used is very good. no other strategy comes in my mind now. if you insist on getting a better quality, play on node spacing. make it smaller, may be it should help...
nitinbansal184 likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   August 21, 2012, 09:53
nitin bansal
Basically I am Going run this model in fluent with K-Omega,translational flow configuration...
I am not able to validate the results..
Old   August 22, 2012, 03:19
cfd seeker is on a distinguished road
I guess your problem is not due to the quality of mesh. I once used this Transition k-kl-w model to validate results for the flow over aerofoil and I noticed that this model is very sensitive to free stream turbulence parameters and also wall y+. Please check upon these after consulting Fluent's User and Theory guide.
cfd seeker is offline   Reply With Quote
meshing quality
[ANSYS Meshing] 2-Way FSI meshing problem using ANSYS 13 workbench john881129 ANSYS Meshing & Geometry 0 January 9, 2012 02:19
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
ICEM Tetra Meshing problme kambireddy ANSYS Meshing & Geometry 3 October 5, 2010 20:17
[ICEM] Meshing problem from ICEM CFD to Fluent cfdonlinederafa ANSYS Meshing & Geometry 2 September 21, 2010 17:16
ICEM meshing problem Forrest CFX 4 May 25, 2005 19:37
