[ICEM] Assigning different number of nodes to parallel edges |
July 22, 2012, 12:37 |
Rohit Bhaya
Hello everyone,
I have developed a geometry in ICEM CFD, whose blocking structure is defined in the pic below. I have been trying to assign different nodes to the edges A & B (in the fig), but wasn't successful in doing so. On assign the nodes to one of the edge(blocking --> Pre mesh params --> edge params), it gets updated to the other parallel edges. I have tried - 1.) specifying the number of nodes to each and every edge 2.) converting the nature of blocks to free/swept instead of mapped but the result would be same. I require that the edges A & C(in the fig) should have the same number of nodes, which would be different from B & D. Can anyone, please guide me on how to pursue with this problem. Thanks Rohit Last edited by Rohit; July 22, 2012 at 12:41. Reason: figure not uploaded properly |
July 22, 2012, 16:45 |
Alex
Rep Power: 49 |
This is impossible if you want to create a hexahedral mesh.
Opposing edges of a block must have the same number of nodes. |
September 23, 2015, 21:35 |
Cristian Osorio
Hi, flotus1, related to the same question, can be parallel edges in different blocks, dissociated?
September 22, 2017, 10:16 |
#4 | |
Camille Bilger
Rep Power: 13 |
I have the same problem but my edges are parallel but not of the same length... so obviously I have calculated on paper the number of nodes each edge would need to have to avoid hanging nodes... but I cannot set those numbers, since ICEM changes them, hence creating hanging nodes. |
icem cfd 13.0 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[ICEM] Dissociate blocks number of nodes | gi12 | ANSYS Meshing & Geometry | 2 | February 23, 2012 23:33 |
Issue with running in parallel on multiple nodes | daveatstyacht | OpenFOAM | 7 | August 31, 2010 18:16 |
Minimum number of nodes to run CFX in parallel | Rui | CFX | 3 | April 11, 2005 21:46 |
