[ICEM] For the geometry change
Like Tree1Likes
  • 1 Post By PSYMN
Old   July 13, 2012, 14:04
Question For the geometry change
lnk
lnk
lnk is on a distinguished road
I'm trying to modify my geometry to make my mesh generation easier. But how do I know how much will that modification influence my fluid behavior simulation results?
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Old   July 16, 2012, 16:43
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, an age old question... how much can you simplify the experiment and still have meaningful results...?
For instance, i was working on submersible probes a couple years ago... These are little (less than 20cm) torpedo things than spin when you drop them in the water. They are supposed to send back sensor readings on their way down.
Our simulations were not predicting the correct behavior because we had left out a small seam (part of the manufacturing process that was not even included in our original CAD models, never mind something we intentionally removed) running from nose to tail. When spinning, this small seam was severely disrupting the boundary layer in a way that the CFD didn't predict, it actually helped the probe fall faster.
What you will need to do is validate your CFD results with physical testing... Until then, you are just guessing that you made the right compromises.
lnk likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   July 16, 2012, 17:01
lnk
lnk
Thank you very much!
Best,
lnk
geometry in fsi berelian90 CFX 1 October 25, 2010 09:53
How can I change view to geometry in FLUENT John FLUENT 2 June 25, 2007 08:54
Restarted run and change in geometry...question Vanessa CFX 3 August 28, 2006 08:55
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Geometry setup for phase change problem Fred G. Kang Main CFD Forum 1 October 14, 1998 12:41
