[ICEM] Question about the use of ICEM tcl scripting
Like Tree10Likes
  • 5 Post By PSYMN
  • 5 Post By PSYMN
Old   July 12, 2012, 16:51
Question Question about the use of ICEM tcl scripting
lnk
lnk
lnk is on a distinguished road
I'm using the ICEM tcl scripting right now. But there are still something about it not clear to me.
The tcl scripting is able to record all my commands at ICEM, so that if I have an idea about changing the geometry to improve my fluid dynamics behavior, I can change it very quickly.
But my project geometry is complex and there are a lot of points. Sometimes if I intend to change the diameter of a circle of my geometry, it takes me a lot of time to find out the correspondent points and change several points very carefully.
I'm wondering is there any way that I can parameterize my geometry like defining the diameters of the circles by parameters so that I can change them easily?
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Old   July 13, 2012, 09:43
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes... You can read about this in the programmers guide. (under the Help menu)
In the commands you can use a $variable. At the top of the script, you could "set variable" to some value...
For instance, at the top of the window you could type the following...
global tdv_current_viewer
set rotate_angleX 1
set rotate_angleY 2
set turns 5
This would be creating 3 parameters and setting their values to 1, 2, and 5.
you could then use these in expressions to create other parameters (if you want)
set angleX [expr ($rotate_angleX * 3.14159) / 180]
set angleY [expr ($rotate_angleY * 3.14159) / 180]
And then you could either use these directly in a line of your replay or create a fancy for loop like this (it basically just rotates your model in view screen)...
for {set cur_angle 0} {$cur_angle < [expr 360 * $turns]} {set cur_angle [expr $cur_angle + $rotate_angleX]} {
tdv_rotate_axis $tdv_current_viewer 0 1 0 $angleY
#tdv_rotate_axis $tdv_current_viewer 1 0 0 $angleX
tdv_trans_update $tdv_current_viewer
update
Any command you find in the replay can have any number replaced with a $variable or even a $array like this next example.
ic_geo_cre_bsp_crv_n_pnts HELIX "" $pnt_list 0
Just for fun, here is another script. This one makes a helix. The instructions at the start tell you where to put this file and then how to run it from the ICEM CFD message window. You could also add this to the UI with a little more effort. In this one, you set all the initial variable values as you launch the script... (that proc line), and then other variables are calculated from those and used in a loop to generate the points and finally the helix.
## source "path"/helix.tcl
## helix
## p1: Center point of base
## d: Diameter of coil
## h: Height per turn
## n: number of turns
## eg. type "source helix.tcl"
## and then type "helix "10 5 2" 1 3 3 curve"
proc helix {p1 d h n {fam ""}} {
set pnt_list ""
set h_he [expr $h/round($n)]
set hei_s [expr $h_he/20.0]
set ang_s [expr 2*3.141592654/20.0]
set d_z 0
set alfa 0
while 1 {
set x_cor [expr [lindex $p1 0]+$d*cos($alfa)/2.0]
set y_cor [expr [lindex $p1 1]+$d*sin($alfa)/2.0]
set z_cor [expr [lindex $p1 2]+$d_z]
set d_z [expr $d_z+$hei_s]
set alfa [expr $alfa+$ang_s]
set pnt[list $x_cor $y_cor $z_cor]
lappend pnt_list $pnt
if {$d_z > $h} break
if {$fam == ""} {set fam "HELIX"}
Far, Ludvik, lnk and 2 others like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   July 13, 2012, 09:51
Default R14.5 has checkbox parameters...
PSYMN's Avatar
Simon Pereira
One other fun bit of information...
In R14.5 (due out later this year), we have added the ability to just click a checkbox to parameterize ICEM CFD (like you would in DM or ANSYS Meshing)...
You can even use them to create blocking edge parameters
These parameters are then driven by the Workbench Parameter manager.
Of course, this only works when ICEM CFD is launched from within Workbench...
Far, sshah, leoly and 2 others like this.
Old   July 13, 2012, 09:53
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Great. It find it interesting.
Far is offline   Reply With Quote
Old   July 13, 2012, 09:55
Far
Sijal
Will parametrization replace the Tcl scripting in R14.5?
Old   July 13, 2012, 10:42
PSYMN's Avatar
Simon Pereira
Oh no, TCL scripting is a very important part of ICEM CFD... Users would RIOT if we ever threatened to take it away.
This new parametric ability is more about ease of use and connection with the Workbench Parameter manager. TCL scripting still offers more flexibility and power.
In fact, you can also define parameters in Workbench for use in ICEM CFD replay scripts (instead of setting the variable in the script, it is driven by the workbench parameter manager). We are working on a tutorial right now and will release it with the software.
Old   July 13, 2012, 14:37
lnk
lnk
May I ask if I have iterative geometry, could I make a iterative loop for it? How? And since the curve and points name are not iterative, how to solve that problem?
lnk
Old   July 13, 2012, 15:49
PSYMN's Avatar
Simon Pereira
Yes, you can.
I suggest you start simple and grow from there. Take a look into the programmers guide for more help. There are many things you can do once you understand the basics.
Old   January 16, 2013, 06:42
Matthias Voß
mvoss is on a distinguished road
Was the mentioned tut released with WB 14.5 update as i would really want to know more about using wb-parameters within an TCL script.
mvoss is offline   Reply With Quote
Old   January 16, 2013, 10:24
PSYMN's Avatar
Simon Pereira
I showed a live demo of how to turn an ICEM CFD script into one that uses Workbench Parameters during a webinar last Thursday. You can find the recording on the ANSYS website (Here and search for ICEM ) (or here is the download link .
I will re-record it for Youtube at some point...
You can also find the instructions if you go into the workbench help (no the ICEM CFD help) and do a search for ICEM CFD... Read down the ICEM CFD Component page until you find the Custom Input Parameter section. It explains the process there.
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX Araz ANSYS Meshing & Geometry 1 April 25, 2011 12:03
question on ICEM CFD Tetra peiyong wang CFX 2 September 3, 2008 19:35
ICEM CFD 11 Question Raj CFX 2 June 25, 2008 03:11
ICEM -CFX a basic question Al Mazdeh CFX 2 April 5, 2008 12:51
ICEM 10 mesh scale foe CFX Korsh Mik CFX 2 October 7, 2005 10:07
