[Other] y+ in practice
Like Tree1Likes
  • 1 Post By everdimension
Old   June 9, 2012, 09:52
Default y+ in practice
Robert
Kwiaci is on a distinguished road
Recently I have started meshing some simple geometries for heat-flow problems. I have encountered something like y+ coefficient. I understand basics of theory for this but I still have problems with usage of this. How should I use it?
If I have simple turbulent flow in a tube of given diameter how can I calculate mesh size for it using y+? Can anyone explain it to me in the easy way?
Kwiaci is offline   Reply With Quote
Old   June 9, 2012, 10:09
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
This can help you a lot :
http://www.cfd-online.com/Forums/flu...-diffuser.html
http://www.cfd-online.com/Forums/flu...h-correct.html
If yous search the forum in the y+ you will find a lot of threads about it.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 9, 2012, 13:53
everdimension is on a distinguished road
I would also recommend reading this: http://tinyurl.com/bs6rla7
Sixkillers likes this.
everdimension is offline   Reply With Quote
Old   June 9, 2012, 15:56
Robert
I am familiar with this article and OK, I understand for which turbulence what value of y+ should be used. But my question is how can I calculate size of the first cell next to the wall using this value and obtain size in mm?
I have found CFD Online y+ estimator and there is sth like boundary layer length - is this length of the entire boundary layer or just let's say length of the turbulent part? In the simple pipe will it be its length?
Old   June 9, 2012, 19:33
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
Y+ should not ideally lie in the range of 5 to 30.. this is where laminar to turbulence transition takes place.
It should not lie in this range bcos capturing physics in the transition layer is quite a task in itself.
So i generally run the fluent for around 50 iterations and then check the Y+ value. If Y+ has to changed then i come back to my meshing software to redo the mesh as required (to either coarsen or refine)..may be you can try this procedure..
Concept of Y+ calculation can be read separately...
Ananthakrishnan is offline   Reply With Quote
Old   June 10, 2012, 09:51
Sixkillers is on a distinguished road
layer length is basically characteristic length. For a pipe it is usually its hydraulic diameter. For a flat plane it is its length and so on.
Sixkillers is offline   Reply With Quote
meshing advice, y+ coefficient
Any free Best Practice Guidelines? lakeat Main CFD Forum 3 January 11, 2012 17:10
CFX best practice for external flows siw CFX 5 May 3, 2009 23:44
Modelling Airfoil Flow Best Practice Ian Main CFD Forum 0 October 3, 2007 08:19
who has ERCOFTAC Best Practice Guidelines ? sarah_ron FLUENT 1 September 27, 2004 08:17
best practice guidelines novice Main CFD Forum 4 August 12, 2004 12:52
