[ICEM] Can I define periodic boundaries in an unstructured mesh? |
May 28, 2012, 13:19 |
Kora
Rep Power: 15 |
Hi all. I'm modelling a tidal stream turbine. To reduce the size I only built 1/3 of the turbine with periodic boundaries. I defined periodicity in global mesh parameters and generated the mesh. But when I read it in FLUENT it can only recognise one of the periodic boundaries.
I've read a few threads regarding to periodic boundaries, and it seems that to define a periodic boundary I would need to define the periodic vertices from the corresponding block after I define periodicity in global mesh parameters. Is that the reason why my mesh doesn't work properly? However, I'm currently doing an unstructured mesh and it doesn't have any blocking. Does it mean that I cannot define periodic boundaries on an unstructured mesh? Are there other ways to work round it? Thanks in advance. |
June 13, 2012, 10:01 |
Yon Han Chong
Rep Power: 14 |
I am not sure what you are trying to do but you can do periodic boundary with unstructed mesh.
June 13, 2012, 10:38 |
#3 | |
Kora
Rep Power: 15 |
I don't know what's wrong with it. I checked the mesh, which doesn't seem to have any problem. But when I try to solve it in fluent it diverge straight away. I was told that there should be two faces for the periodicity but when I important it into fluent it could found recognise the top one. |
June 13, 2012, 10:50 |
Yon Han Chong
Rep Power: 14 |
Recognizing the only one side is normal.
Why don't you run one iteration and check the solution. You could also try the fmg-initialization and check the solution. You have to refer to the manual for this as this option is only available through Text User Interface. However, it could give you very good initial guess of the solution. If the fmg-initalization fails I would check your boundary condition again including the periodic axis definition in fluid domains. Fluid might be cyclic in an wrong axis. |
June 16, 2012, 15:21 |
Khayyamian
Rep Power: 16 |
If you are working with ICEM go to view menu and Mirrors and replicates, and generate the 2nd part of the mesh and you can check manually that your nodes are matching (i.e. conformal mesh) Also check your mesh in the edit mesh tab . this is very useful! In your fluent did you set periodic boundary condition? |
June 19, 2012, 11:24 |
#6 | |
Kora
Rep Power: 15 |
In FLUENT I only set periodicity as rotational at boundary condition. Are there anything else that I need to set up in FLUENT? This is the first time for me to set up a periodic boundary condition, I might have missed something that I didn't know about. |
June 19, 2012, 11:35 |
Khayyamian
Rep Power: 16 |
However there are other advanced settings, I guess thats fine. now, what is your problem?
June 19, 2012, 11:43 |
#8 | |
Kora
Rep Power: 15 |
Divergence detected in AMG solver: pressure correction Divergence detected in AMG solver: k Primitive Error at Node 0: floating point exception Primitive Error at Node 1: floating point exception Primitive Error at Node 2: floating point exception Primitive Error at Node 3: floating point exception Error: floating point exception Error Object: #f I've never seen something like this happened before so I don't even know which bit of it is wrong: whether is the mesh or the setting in FLUENT. |
June 19, 2012, 12:38 |
#9 |
Yon Han Chong
Rep Power: 14 |
You need to set the rotational-axis direction.
Cell Zone Conditions -> Zone, Edit As I said, stop or write out after few interations to check the boundary conditions. |
June 19, 2012, 13:34 |
#10 |
Kora
Rep Power: 15 |
Hi guys, thanks very much for your help and information.
The model is working now. Probably because I missed defining the axis. Thanks again. |
August 1, 2013, 22:57 |
Translational periodic condition in icem cfd
#11 |
Rijas
Rep Power: 13 |
Hi could any one tell me how to set translatinal periodic condition for a cascade airfoil?
September 14, 2018, 02:52 |
#12 |
ShahzadHassan
Rep Power: 8 |
hi dear i am also doing something very similar right now i need to know that just defining periodicity and axis in global mesh parameters( axis + angle) would suffice creating two periodic sides ( as you did i am also working on a turbine similar to this one) ? Or i need to define periodic vertices ( how to do that if i had to do that) ? Please reply please
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[ICEM] mesh periodicity without any periodic boundaries | Will Anderson | ANSYS Meshing & Geometry | 3 | November 26, 2010 19:51 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
