[ANSYS Meshing] Why doesn't ANSYS Meshing allow me to make a very fine mesh?
Like Tree2Likes
  • 1 Post By ali.qasim
  • 1 Post By scipy
Old   May 21, 2012, 12:04
Default Why doesn't ANSYS Meshing allow me to make a very fine mesh?
Ali
ali.qasim is on a distinguished road
I'm trying to make a C-mesh over an airfoil.
The first image shows my original mesh. But when I try to increase the bias factor or the number of divisions, so as to improve the resolution near the airfoil, I get the second image.
Any idea why this is happening?
James Hetfield likes this.
ali.qasim is offline   Reply With Quote
Old   May 22, 2012, 04:50
scipy's Avatar
Alex Pasic
scipy is on a distinguished road
Send a message via Skype™ to scipy
For mapped face to work, you have to increase the bias/number of divisions on all Edge sizing functions. U've probably been following the Cornell airfoil in WB tutorial, so, just increase the number of divisions on the left part too (C grid) so it'll have the same number of divisions as the wake part on the right.
PSYMN likes this.
scipy is offline   Reply With Quote
Old   May 25, 2012, 20:11
Default Inflation
Ricardo
ricardo.costa is on a distinguished road
Hi ali.qasim,
By doing what our friend said about increasing the number of elements probably you will find a solution for the related problem.
Have you tried to built some inflation layers on this aerodynamic profile? I am trying to do this, but I cant find a solution.
Thanks,
Ricardo
ricardo.costa is offline   Reply With Quote
Old   May 26, 2012, 05:48
Ali
scipy: Thanks. That did work up to an extent, but the problem came up again when I wanted more biasing. I guess I'll have to just start learning ICEM-CFD.
ricardo: I haven't tried inflation layers. Will do so and let you know if the problem is solved.
Old   May 26, 2012, 07:04
Ali
Just realized inflation won't work as the domain is divided into four faces around the airfoil.
bias factor, fine, mesh
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
ANSYS Meshing - DC Mesh Quality alven299 ANSYS Meshing & Geometry 5 July 19, 2010 12:34
[Commercial meshers] How to make a good Low-Re Mesh ? Gearb0x OpenFOAM Meshing & Mesh Conversion 0 February 12, 2010 05:48
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
