[ANSYS Meshing] Very thin plate (0.1mm) ICEM CFD bad meshing
Like Tree1Likes
  • 1 Post By FSB
Old   April 27, 2012, 03:01
Default Very thin plate (0.1mm) ICEM CFD bad meshing
June
msormania is on a distinguished road
Height of the thin water layer is 0.1mm and diameter of the thin water layer is 490mm.
For tansient hydrodynamic analysis, height should have at least 5 layers.
I tried to apply 5 points for the height edge but, it is making bad meshes.
If I use 2 layers, it is 100% quality by determinant 2*2*2.
After going over 3 layers, it is generating bad meshes around outside boundaries. For better understanding, I attached the snapshot of bad meshes and stp file.
Can you rename water_zone_tin.c to water_zone_tin.tin?
Can you rename water_zone.c to water_zone.stp after download in order to import geometry?
How can I improve the mesh quality?
Aspect ratio is very bad.
I appreciate sincere help in advance.
msormania
msormania is offline   Reply With Quote
Old   April 30, 2012, 08:45
FSB
FSB is on a distinguished road
Go to menu "settings" and select "model".
In both fields "Topo Tolerance" and "Triangualtion Tolerance" enter: 1E-40.
Save project and remesh, it should work .
Ralen likes this.
FSB is offline   Reply With Quote
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 04:42
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface James Date CFX 3 August 10, 2012 05:47
ICEM CFD use for ? Vu Trinh Tuan CFX 14 April 11, 2011 19:38
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 17:14
ICEM CFD Meshing Problems: Hexa Dominant Evan CFX 6 July 3, 2006 13:37
