How to plot contour lines in Tecplot 360 using Excel file |
February 15, 2012, 02:55 |
Iqbal
Rep Power: 15 |
I am using Tecplot 360. I want to draw some contours line using Excel data import to Tecplot 360. I have gone through the user guide, but have not understood how to do it. I can import data from excel to Tecplot but can not draw contour line. Does anyone can help me that how i can draw contour line in Tecplot importing data from a excel file? If anybody has an example file where there are step-by-step guidelines, it would be helpful for me. Regards Iqbal |
May 30, 2012, 20:22 |
Tecplot 360 Tutorial: Showing Countours from Surface Points
Straton Spyropoulos
Rep Power: 14 |
In this Tecplot tutorial, you will learn how to view your contours after your have loaded data into Tecplot 360:
http://www.youtube.com/watch?v=3FMTLQ-ozKA |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 12:47 |
Transfer low-res graphic file plot to excel plot | quarkz | Main CFD Forum | 3 | April 9, 2009 14:54 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
