December 15, 2010, 22:51 |
Tecplot 360
Gloria
Rep Power: 16 |
Hi, everyone,
Who knows how to change axial value to relative value in the Tecplot, for example, current value/5? Thanks |
December 20, 2010, 17:57 |
Changing axial values in Tecplot 360
Scott Rumage
Rep Power: 17 |
Hello Lig,
This can be accomplished in Tecplot 360 by creating a new variable via the data alter command, and then setting the new variable as a new axis. Via the Tecplot menu , go to Data>>Alter>>Specify Equations {new variable}=0 And then {new variable}= [current value]/5 More details on how to do this can be found on www.tecplottalk.com , with a suggested search keyword of “alter”. Information on the “Data>>Alter” command is also located in the user manual in Chapter 21 (page 299): http://www.tecplot.com/Support/Documentation.aspx A more general description on shifting frames of references for analysis of heterogeneous data is described by Dr. Scott Imlay, Tecplot’s Director of Research, in this white paper: http://www.tecplot.com/Community/Whi...neousData.aspx (note: this paper is not a Tecplot tutorial). Regards, Scott |
December 20, 2010, 22:41 |
Gloria
Rep Power: 16 |
Thank you very much, Scott, I got it.
Getting Star-CCM+ results to tecplot 360 | Nathan | Siemens | 3 | April 4, 2017 15:18 |
CFX-Post and Tecplot 360 | Rogerio Fernandes Brito | CFX | 2 | September 28, 2008 15:45 |
Exporting to Tecplot 360 | Rogerio Fernandes Brito | CFX | 1 | March 24, 2008 16:51 |
tecplot 360 vs. 10 compatibility | N.R. | Tecplot | 6 | December 12, 2007 14:23 |
Exporting data to Tecplot 360 | Genesis | FLUENT | 2 | June 6, 2007 18:53 |
