Home > Forums > Visualization & Post-Processing Software > Tecplot
tecplot 3D velocity contours inside a channel
Old   July 14, 2010, 19:37
Default tecplot 3D velocity contours inside a channel
Naveen
vetnav is on a distinguished road
Hi fellas,
I am trying to do something like this, lets say we have a 3D channel with square cross section and the flow enters with uniform velocity and become fully developed and finally ends up as a parabolic velocity profile (paraboloid in 3D).
I want to show the 3D contours of the stream wise velocity inside the 3D channel. The procedure I follow is I cut a slice at a constant X location (X being the stream wise direction and Y,Z are normal and span wise directions) so this slice (which is 2D surface) becomes ZONE2 I deactivate the ZONE1 (which is 3D channel), now in active ZONE2 I change the X-axis variable to u (which is stream wise velocity) and Viola I could see a paraboloid but if I want to put this paraboloid inside the 3D channel as one of the axis variables is changed when I activate the ZONE1 I don't see 3D channel geometry, its all get distorted.
So can anyone please tell me how to show the development of the flow inside a 3D channel flow using 3D contours of the velocity at different locations inside the channel.
Thanks
vetnav is offline   Reply With Quote
Old   July 14, 2010, 20:33
Default Frame control inside of Tecplot
Scott Rumage
scott_rumage is on a distinguished road
Hello Vetnav,
I believe the solution to your dilemma is to open a new frame in Tecplot (because you have two different coordinate systems), and then superimpose the 2D surface “frame” back onto the 3D channel frame.
Here is a link on the Tecplot web site that explores this concept and may be helpful: http://www.tecplot.com/Training/PlotTips/FramesStreamtraceControl.aspx
Regards,
Scott
scott_rumage is offline   Reply With Quote
Old   July 14, 2010, 20:39
Naveen
Dear Scott,
Thank you for the reply, but if I link the frames, if I change axes variables in one frame the other frame is also getting effected.
Thanks you
Old   July 14, 2010, 21:00
Default Iso-Surfaces
Scott Rumage
Okay, sorry for the ineffective suggestion. Does creating iso-surfaces of various velocities help you visualize the 3D velocity contour?
Old   July 14, 2010, 21:03
Naveen
I tried plotting Iso-surfaces also but it is of no use.
Velocity reduces in channel Rayan FLUENT 11 December 1, 2010 01:38
Velocity Contours sambayo FLUENT 2 October 12, 2009 05:49
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 19:42
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
on unconvincing results for channel flow simulatio yf yap Main CFD Forum 6 January 30, 2001 00:18
