Streamlines under Moving reference frame; Spiral streamline from Tecplot |
Rep Power: 17 ![]() |
I plot streamlines based on velocity field for a rising bubble using Tecplot and my own program. In Tecplot, I got SPIRIAL streamlines inside bubble, which should be closed streamlines (closed loops). I found a similar discussion posted before in this forum but was not given a solution (http://www.cfd-online.com/Forums/mai...treamline.html). I also calculated stream function in my own program. However, the plot of streamlines (contour plot) looks like the streamlines in Stationary reference frame. I use Moving reference frame (which is attached to the rising bubble). I did correct boundary conditions for stream function corresponding to Moving reference frame. Should I correct the governing equation (vorticity) too? (It is related to the derivative of z-velocity which should not be affected by adding a constant or not). I appreciate any idea. ![]() |
Ananda Himansu
Check that the stream function calculated in your own program gives you the correct streamlines when there is no bubble, i.e., the streamlines of a uniform flow at the negative of the bubble velocity. Then keep in mind that while the vorticity (being a derivative of the velocity) is unaffected by adding a constant to the velocity, the stream function on the other hand (being an integral of the velocity) is indeed changed by adding a constant to the velocity.
Thanks a lot for your timely help, Ananda. I will give a try about what you said. |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Help for Moving Reference Frame. | aiqch | Main CFD Forum | 0 | April 3, 2009 00:23 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
