Home > Forums > Visualization & Post-Processing Software > Tecplot
How to Set NaN for a Variable in Tecplot 360 EX 2018 R2?
Old   October 29, 2024, 15:47
Default How to Set NaN for a Variable in Tecplot 360 EX 2018 R2?
Lemuel Ramos
LemuelCRA is on a distinguished road
Hello, I'm working in Tecplot 360 EX 2018 R2 and am trying to set all values of a specific variable to NaN for just one zone. My aim is to label nodes in one zone without cluttering the view with labels from another. That's why I thought maybe setting NaNs could do the 'blanking' job.
Specifically, I want to set the variable {Head} to NaN in a particular zone. I attempted using the Specify Equations tool with the command:
{Head} = NaN
However, this results in an error:
Unrecognized Command. Error occurred near position marked with "@" below:
{Head} = @NaN
Has anyone encountered this or know of alternative methods to accomplish this? Any advice would be appreciated!
Thanks!
LemuelCRA is offline   Reply With Quote
Old   November 8, 2024, 12:52
Scott Fowler
wsfowler is on a distinguished road
Interesting idea. Tecplot 360 hasn't really been designed to handle NaN values, but I ran a little experiment to try your idea.
I was able to set data values to NaN using our PyTecplot API by doing the following.
1) Allow Python connections via "Scripting > PyTecplot Connections" and toggle on "Accept connections"
2) Run the following Python code to set the "C" variable of the second zone to NaN
import tecplot as tp
import math
tp.session.connect()
ds = tp.active_frame().dataset
num_points = ds.zone(1).num_points
ds.zone(1).values("C")[:] = [math.nan]*num_points
With NaN values, Tecplot 360 2024 R1 still renders the data labels and displays them as "NAN". However, Tecplot 360 chooses to not render the contour coloring for that zone.
It appears that, at this point, there's no way to have a zone "opt-out" of rendering the Point/Cell labels.
If you'd like to make a formal request for us to update this behavior, please contact our support staff at support@tecplot.com.
Thanks,
Scott
wsfowler is offline   Reply With Quote
Old   November 10, 2024, 21:15
Lemuel Ramos
Thanks Scott!
I will opt for the request.
label, nan, tecplot 360
does Hyperthreading affect the application of UDF? SJSW Fluent UDF and Scheme Programming 11 October 10, 2018 23:28
ThirdParty compilation error during OF-1.6-ext installation achyutan OpenFOAM Installation 21 February 28, 2013 06:58
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 5 May 12, 2006 19:42
Problems with installation jonititan OpenFOAM Installation 4 November 6, 2005 05:16
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 11:15
