October 12, 2024, 18:29 |
Contour not showing on slices of Tecplot
Rizvi Arefin Rinik
Hi
I am simulating a CFD Heat exchanger (DPHE) that consists (hot fluid domain,cold fluid domain, and outer and inner pipe) now if i select slices then only shows on surfaces of pipe but not capturing all domain like in post CFD. Please help me urgent. Thank you. |
October 17, 2024, 12:20 |
gibson
Hi Rizvi,
Have you extracted the domain data for the slice? You can visualize the volume data from within the domains if you extract the slice. More info here: https://tecplot.azureedge.net/produc...slices/extract Feel free to email support@tecplot.com if you have any questions. |
Incorrect showing for the contour in Tecplot 360 | bhbuaa | Tecplot | 0 | August 12, 2014 13:46 |
Showing contour height | flow_CH | Tecplot | 1 | July 22, 2013 12:08 |
How to plot contour lines in Tecplot 360 using Excel file | Iqbal | Tecplot | 1 | May 30, 2012 20:22 |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 13:48 |
Tecplot problem of plotting boundary in contour | mafoi | Tecplot | 1 | April 5, 2005 07:43 |
