Turbo surface in different spanwise for impeller |
June 21, 2024, 05:35 |
Rep Power: 3 |
Hello everyone,
As known to us, the CFD-Post could utilize the turbo Mode to create turbo surface.But in Tecplot or Ensight, the function is missed.As a result, is it possible to create a surface with expression? By now, I haven't figured out the expression of it. I would be very appreciated if anyone could give me a hand! Memorise Best wishes Last edited by Xuxu; June 21, 2024 at 05:36. Reason: Tecplot, turbomachine,turbo |
June 23, 2024, 22:26 |
Svetlana Tkachenko
Rep Power: 14 |
What surface would you like to generate? Is it the surface of the propeller?
June 24, 2024, 04:10 |
#3 | |
Rep Power: 3 |
Yes. I want to generate the turbo surface at different spanwise within the impeller. The name of turboSurface is called by CFD-Post-Turbo Mode. In the figure, the gary surface is the 50% spanwise surface. |
June 26, 2024, 08:44 |
#4 | |
Jens
[snappyHexMesh] snappyHexMesh and CfMesh: Surface is not smooth | mortezahdr | OpenFOAM Meshing & Mesh Conversion | 2 | April 29, 2024 21:59 |
[snappyHexMesh] Generating Surface Layers Around Winglet Airfoil | Snacker | OpenFOAM Meshing & Mesh Conversion | 4 | March 11, 2024 05:16 |
How to use the Turbo Slicing Surface tool on Star-CCM+ | DC1998 | STAR-CCM+ | 0 | November 11, 2020 12:32 |
How To Create Fowcs William Hawkings Surface in Fluent? | marinkobezu | FLUENT | 7 | October 25, 2018 10:51 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
