Home > Forums > Visualization & Post-Processing Software > Tecplot
Unwanted lines on 2d slice plane in tecplot
Old   May 7, 2024, 12:37
Default Unwanted lines on 2d slice plane in tecplot
Ali Salehpour
alisalehpour is on a distinguished road
Hello everyone,
Whenever I want to plot streamlines or mesh on a plane that I have defined in Tecplot, some undesired lines will appear (as seen in test.jpg). Is there any solution to solve this issue?
Thank you
alisalehpour is offline   Reply With Quote
Old   May 20, 2024, 14:01
Scott Fowler
wsfowler is on a distinguished road
This looks like you may have a multi-block solution and those are the boundaries between the blocks. I'd try turning off "Mesh" and "Edge" style. If that still doesn't work, please reach out to our support staff (support@tecplot.com) and we'll see if there's anything else we can do.
Thanks,
Scott
wsfowler is offline   Reply With Quote
Old   May 20, 2024, 15:43
Ali Salehpour
Thanks,
Scott
Thank you for your reply.
Yes, you are correct and the problem corresponds to parallel computation. After computation, I reopened the fluent files with only ONE core and exported the result and it solved the problem.
Regard,
Ali
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 03:08
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Cutting a slice in Tecplot siamakghh2000 Tecplot 2 September 14, 2013 06:24
How to plot contour lines in Tecplot 360 using Excel file Iqbal Tecplot 1 May 30, 2012 20:22
