Home > Forums > Visualization & Post-Processing Software > Tecplot
Tecplot convert to SZPLT single our double precision?
Old   April 29, 2024, 18:46
Default Tecplot convert to SZPLT single our double precision?
Nikolaos Beratlis
nikosb is on a distinguished road
When using the tec360 -convert command option to convert a Tecplot ASCII file to SZPLT file, for example:
tec360 -convert tecplot.dat -o tecplot.szplt
, can one specify single or double precision for the final szplit file?
nikosb is offline   Reply With Quote
Old   May 6, 2024, 18:06
Scott Fowler
wsfowler is on a distinguished road
When converting ASCII files using:
> tec360 -convert ascii.dat -o binary.szplt
-or-
> preplot ascii.dat binary.plt
The data type defined in the ASCII file will be honored. If the data type is not specified, single precision is assumed.
In the header of the ASCII file below you can see the "DT" line, which specifies the data type. You may need to add this line to your ASCII files to get the data type you want when converting to binary.
I hope this helps,
Scott
TITLE     = "Internally created data set"
VARIABLES = "X"
"Y"
"Z"
"Single"
"Double"
"LongInt"
"ShortInt"
"Byte"
"Bit"
ZONE T="Rectangular zone"
 STRANDID=0, SOLUTIONTIME=0
 I=10, J=10, K=10, ZONETYPE=Ordered
 DATAPACKING=BLOCK
 DT=(SINGLE SINGLE SINGLE SINGLE DOUBLE LONGINT SHORTINT BYTE BIT )
 0.000000000E+00 1.111111119E-01 2.222222239E-01 3.333333433E-01 4.444444478E-01
 5.555555820E-01 6.666666865E-01 7.777777910E-01 8.888888955E-01 1.000000000E+00
wsfowler is offline   Reply With Quote
szplt
Warning message C4133 while compiling Arminius Fluent UDF and Scheme Programming 0 October 2, 2017 12:44
Single precision better than double precision? 140raiders CFX 1 July 30, 2015 03:32
Switch from single precision to double precision kk81 OpenFOAM Bugs 0 March 11, 2010 07:14
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
OpenFOAM Double precision vs Single Precision alexandrepereira OpenFOAM Running, Solving & CFD 1 June 11, 2008 15:30
