Parth
Rep Power: 5 ![]() |
Hi I am trying to import the openfoam case for the post processing using
controldict from tecplot layout loader in OpenFOAM(FEA) file type, but i am getting error saying : "No nodes or elements detected" pls help |
Scott Fowler
Rep Power: 17 ![]() |
What version of Tecplot 360 are you using? Tecplot 360 2023 R1 has fixed a couple issues with the OpenFOAM reader. If you're experiencing this issue with 360 2023 R1, I'd suggest you contact our support staff at support@tecplot.com. We'll likely need the data file to diagnose the issue.
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
[Commercial meshers] Unknown error when converting fluent mesh to openfoam | Yutao | OpenFOAM Meshing & Mesh Conversion | 0 | April 23, 2023 02:30 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
[Other] converting mesh data from tetgen to Openfoam!!! | soankerabhinay | OpenFOAM Meshing & Mesh Conversion | 4 | February 16, 2015 20:01 |
