Calculate spanwise lift and drag distribution |
September 17, 2023, 05:10 |
Hannes
Greetings fellow CFD lovers and Tecplot experts,
I am currently analyzing the flow around a three dimensional airfoil + flap configuration, using DLR TAU as the flow solver. I obtain the surface solution for both airfoil and flap, with multiple output variables, primarily c_p and c_f for my case. For my analysis, I want to plot the spanwise distribution of the lift and drag coefficients. From my understanding, that should be possible with the given surface solution and variables. I am using Tecplot for postprocessing, but also have access to Matlab if necessary. Any ideas on how to achieve that? That specific problem came up a few times in different forums, yet with no satisfactory answer. Thanks for any advice! Last edited by 35k; September 17, 2023 at 05:11. Reason: Typo |
September 21, 2023, 16:28 |
Scott Fowler
Rep Power: 17 |
We have a Python script on our GitHub site which should accomplish what you want: https://github.com/Tecplot/handyscri...nts_VS_Span.py
The script has some hard coded values between lines 234-257 that will need to be adjusted for your data. These values work with the OneraM6 dataset that is included in the 360 installation. This script requires PyTecplot, which in turn requires a Tecplot 360 license with active maintenance. The general idea is: 1) Compute Pressure XYZ components using the mesh normal direction 2) Extract a bunch of slices in the spanwise direction 3) Integrate the Pressure XYZ components for each slice 4) Create a new linear zone to store the integrated results vs. slice locations and plot the results If you have active maintenance you can also contact our suppor staff for more help. Scott |
calculate distribution, integrate coefficients, postprocess, spanwise distribution, tecplot |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 07:04 |
How to calculate lift, drag and lift distribution in Star CCM+? | israelcasillas94 | STAR-CCM+ | 4 | November 6, 2020 09:35 |
How does FLUENT calculate lift and drag? | xTamx420 | FLUENT | 0 | May 30, 2011 14:35 |
how to calculate mean value of lift and drag | aamer | Main CFD Forum | 9 | December 21, 2010 01:23 |
spanwise lift distribution plot | Vincent | FLUENT | 2 | May 5, 2006 01:55 |
